Question about Xerox DocuColor 12 Printer
System fault 9-357
How do you access NVRead/Write? I have this problem, but I can't figure it out how to fix it. Any help would be great
  • 446 Answers
Nvram isnt repairable you need to replace this to correct the prob
Posted on Sep 22, 2008
Why is my airbag warning light keep coming on . And bleeping?
The airbag system is stand alone and when the light is lit, the system has registered a fault and is disengaged. The only way to fix it is to get rid of the fault. You will need a scan tool that can access the air bag control module and find out where the issue is.
Feb 11, 2016 | 2005 Chrysler PT Cruiser
STOP fault Running gears
It is transmission fault code, have the dealer scan the system to see which fault code number is stored.
Dec 01, 2013 | 2005 Volkswagen Touareg
Pcm p1520
I found a site for you with the diagnostic codes. There's information available on the site to help you figure out what is causing what ever fault code is coming up and help you figure out what to do to fix it.
Best of luck to ya.
http://www.engine-light-help.com/ford-check-engine-light.html
P1520 Intake Manifold Runner Control Fault
Jul 18, 2013 | 1999 Mercury Cougar
2005 Volvo XC90 backseat entertainment system will not power on.
Remove the unti and put it on the bench and use a DC voltage to power the unit. If this wont power on then there is fault within. It can be serious or minor but unless you start with a flow chart it will be hard to confirm, so start from the fuse and power to the processor .
Jun 06, 2012 | 2005 Volvo XC90 V8
Marapco generator over or under speed led how to cansel
We have this same issue with a Perkins model mp 400E here in Afghanistan. It will start up and run for about 30 seconds at its normal 50HZ 1500 rpm operating speed, then it will gradually start to slow down and shut itself off around 1350 rpm. There are 4 vertical fault lights on the control panel, and the bottom one stays red and refuses to reset. We can't figure out what is causing this fault light or the stalling engine. Any help would be greatly appreciated!
Jan 29, 2012 | Electrical Supplies
I have not ran the system fault code test? What is that?
When there is a failure in one of the many systems and circuits that are monitored by your computer system, the computer stores fault codes that have a corresponding description that will tell you which of the systems or circuits are failing. In order to properly diagnose the problem, you must first retrieve the fault codes from the computer system to get a starting base with which to begin your diagnosis of the problem. Without these fault codes, you can spend a LOT of time and waste a LOT of MONEY trying to figure out what is wrong with your vehicle. Without these fault codes, anyone trying to HELP you figure out what is wrong with your vehicle can do little more than "GUESS" what may be causing the problem.
Please also review the following articles for more information on this subject:
Why Is My Engine Light On?
What Else Could Be Wrong?
Oct 15, 2011 | 1994 Plymouth Voyager
I fixed a paper jam in my Imageclass D320 printer/copier which involved removing both panels and the ink cartridge to get the paper out. Now it says System Errir E100 and I can't figure out how to fix...
E100 is error for laser unit.
Probably the jam occured because fault on laser unit. To fix error you need to reconnect all connectors of laser unit, or in worst case replace laser unit completly.
Call service...
Hope that helps!
Aug 01, 2011 | Canon imageCLASS D320 Digital Copier
Hi the Bios/ Cmos battery on my Asus m51s Laptop has died, at first I had to keep resetting the time now it just goes to black screen anyway my husband wants to try replacing it himself but we cant find...
Go thru the below Link and do the steps.
http://www.youtube.com/watch?v=cg_wvp1YdSI
Replacing the motherboard lithium battery demands some care. It seems to be a simple task, but it is not. The lithium battery may use basically three socket types: socket with upper tab (Figure 1), socket with lateral tab (Figure 2), and the socket into which the battery stands instead of lying (Figure 3). imageview.php?image=187 Figure 1: Socket with upper tab. imageview.php?image=188
Figure 2: Socket with lateral tab.
Figure 3: Another kind of battery socket.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Jun 29, 2011 | Computers & Internet
When I start up 06 Jetta I get Airbag fault. What do I do and is my extended warranty cover it.
If you have an extended warranty you need to call and verify coverage as these policies vary greatly in what they will cover. Some of these policies only cover the powertrain while others cover virtually everything on the vehicle.
Jun 14, 2010 | 2006 Volkswagen Jetta
Noise on rear speakers
yeah i used to have this problem too forever, untill i was playing around with them and figured out the problem. on your remote there is a shift function, while holding shift you need to turn up rear speakers also on the remote, i think its near 1 or 2 or somthing. just look for rear level, turn that up and make sure you have the proper audio setting and that should fix it.
Oct 17, 2006 | JVC MX-J800 CD Shelf System
Xerox DocuColor 12 Printer Logo
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
