Question about Refrigerators
Sagging door on 1 year old Hotpoint with top frezzer.
I see no adjustments and have No manual for this machine.
Installed by Access Inc.
The door has a 1/4 inch crack at the opening side at the top of the door.
How do I cure this? The machine runs a LOT.
    Novelist:
  • 166 Answers
One year old is under warranty and service will come out and take care of the adjustment free!.
Do not wait a minute because you only have a one year warranty on a brand new appliance today! That running is costing you alot of money cause the cold air is leaking out!
bless you,
ngafm
please give me a good rating before you sign off,
Thank you!
Posted on Sep 05, 2008
The top door is frosting on the inside, changed the gasket same problem. It seems the door is sagging down a bit.
You might try loosening the screws on the hinge on top of your refrigerator and then lift up on the corner of the door away from the hinges and then re-tighten the screws. That will help put your door back in alignment and hopefully end your frosting. Hope this helps!
Jan 20, 2015 | Hotpoint HTS18 Top Freezer Refrigerator
Apart from the cover at the base. How do I access the internals of the machine. I have a loud noise on spin plus I seem to have a water leak inside
The front panel comes off. 1st you need to remove the Facia to access the 3 screws...Leak could be door boot seal noise sounds like drum bearings/ if its under 5 years old phone Hotpoint it will cost around £100 for call, parts are free.....If over 5 yaers think new machine as its quite expensive to do full job and not always worth it if old........
Dec 03, 2010 | Hotpoint Aquarius WF215 Front Load Washer
My hotpoint washing machine (model wma50) will not start due to the door lock light flashing yet the door is closed
common problem on these machine's, you need a new door handle which comes as a full assembley with spring and all attached.
open the door, using star screw driver remove top and bottom screws along with two near the catch.
the doo wil split enough to remove old handle and fit new 1.
Oct 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Mar 07, 2010 | Washing Machines
Freezer door on Kenmore AS-18 is sagging
I have this fridge and the sagging door means that you are missing a plastic washer. you might have accidentally placed this washer on the top rather then on the bottom where it belongs.
Jan 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
How to adjust door hinges on fridge
on the door thats sagging on top of the of the door is a cap some have a screw holding it....if not use a screwdriver at the back of the cover and pop it up then you have small bolts some have 2 but most have 3 just loosen up but no need to remove then pull towards the hinge to see it move again move to the to where level you can place something in the gap between the door or have someone hold the door in place then reverse order to complete
Sep 06, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
No power??
It's more than likely its the door lock, if not check the timer contacts on the top front connection block, if they have blown it will need a timer & door lock
Nov 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Motor runs, but no spin.
You don't list model number so this will be a bit generic for Hotpoint top loader. If the motor spins but the belt is not moving: With power off, manually turn the large pulley the belt goes around, just a revolution is enough. Spin is CCW, but you may have to try CW (agitation). Now set turn the washer on spin again. This may unlock your transmission, but unfortunately is usually only a temporary solution. If the machine was manufactured prior to 1-1-06 and still under five years old, the transmission may still be covered under warranty. Check the back pages of your owner's manual. (labor would not be covered) If too old / not covered, I'd invest in a new front loading washer. The LG's are #1 rated in Consumer Reports and are direct drive (with a 7 year warranty on the motor) so there is no transmission, clutch, belt, or pulleys. You don't have to get the top of the line model, all LG's are direct drive and very good. Other front load machines, although not DD, will also use much less water than your hotpoint and spin out twice as fast or more, reducing dry time and dry cost. I know this wasn't what you really wanted to hear (bad news), so don't bother rating this "solution". (don't want my rating to go down just because I told someone bad news about there machine.)
Oct 05, 2008 | GE Hotpoint 2.7 cu. ft. Washer
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
