Question about Zenith Z50PX2D 50 in. Plasma HDTV
Picture comes and goes.
Ok so This is the plasma that likes to go pop and go black after the warranty expires, so after a lot of research I decided to change the YSUS and ZSUS boards witch now I do have a picture again, problem is the screen now comes on then fades off back and forth and when it is on for it's quick little time the picture is also faint. :-/ should I first double check my connections / cables? Thanks
  • 7 more comments
  • euroryde Sep 05, 2008
    How do I go about a reset for it?
    What if this was done with a magnetic tipped screw driver?
  • euroryde Sep 06, 2008
    What if this was done with a magnetic tipped screw driver? would this be causing the problem and or how would I go about fixing?
    Oooo ok ya nothing like that near it.
    Anything else I might be missing that I could check?
    Yes kindofcheap i can see your comment "Hello Can you see my Comment"
  • euroryde Sep 07, 2008
    Would a power supply make the picture faint and go in and out?
  • euroryde Sep 08, 2008
    Double checked connections and still doing the same thing.
  • 4,472 Answers
Have you double checked all your connections? Yes I would say that it is definitely possible. If you have any other questions let me know.
Thanks,
Lee
Posted on Sep 07, 2008
    Genius:
  • 2,035 Answers
To reset the unit you need to unplug the unit from the power and all cables then wait 30 minutes and redo and plug it back ,if face the same problem try in a different power unit and unit...
Good luck...
Posted on Sep 06, 2008
    Sergeant:
  • 241 Answers
  • Jayson Brollini
    Jayson Brollini Sep 06, 2008
    GOOD LUCK trying to see my comment
  • Jayson Brollini
    Hello Do you still need my additional help?
    Sergeant:
  • 264 Answers
Make sure that there is no Magnetic feild around the plasma.
Posted on Sep 05, 2008
  • Sameer Kashyap Sep 06, 2008
    The magnetic tipped screw driver wont hamper anything
    By Magnetic field i mean there should not be any gadget near the plasma which contains a heavy Magnet. It may continuously create a magnetic field which will surely let the picture to fade off.
    Genius:
  • 1,142 Answers
Please check the connections and cables..also try a reset of the system...
Have 52"sanyo plasma .
Hi Michelle.
What you are describing is called " capacitor flu".
The capacitors in your tv produce a charge that energizes the screen, and they are failing on you.
The popping noise is the capacitors trying to send electric pulses to the screen, but because one or more of them are defective, the screen doesn't come on, just sound.
And then when the protection circuit kicks in, it shuts the set back off to prevent further damage.
If your tv is under warranty, then by all means send it in for warranty work.
If, like most, the warranty is expired, then you might find that it is cheaper to get a new tv instead of fixing the old one.
This is because in order to make sure that the problem is completely resolved, the repair center will have to remove and replace every capacitor in the set.
This is a time consuming effort, and can be quite expensive to do.
I wish I had better news for you, but sadly this is not the case.
If you do decide to repair it, Fry's, Staple's, and Best Buy are the safest place to get the repairs done at.
They all have trained service techs for this type of repair.
Good luck to you, ma'am, and have a good day.
Aug 11, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
My screen keeps "looping". starts, goes to black
You can try to get the processor to do a cold start. To do this, unplug the power from the set - turning it off is not enough, you must unplug it!
After 15 minutes, plug the set back in and try to power up. If it works OK, you are good2go!
If that did not work, your set probably has a power supply problem. The best option if it is under warranty is to exchange it.
If your warranty has expired, find a good TV repair shop and ask for an estimate before going any further.
Good Luck!
Feb 13, 2011 | LG 50PG20 50 in. Plasma HDTV
Picture out
Common on this set are bad x and y suatain boards.
Nov 08, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Hitachi 55 inch plasma tv
what type of connector are you using fo your xbox? I think
Dec 13, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Jan 13, 2008 | LG DU-50PX10 50 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Zenith 42" plasma p42w46x
I have just had the same problem. It affects both the component inputs but the A/V inputs are OK. If I disconnect the green input, the screen goes black and displays "No signal." Service guy came out and said the Y-board needed replacing. Haven't done this yet
Sep 01, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Plasma 42inch TV
I'm guessing this is a problem on the Y-SUS PCB or the Control PCB. Call LG and they will find you a servicer. Most LG Plasmas have 2 year warranties and they are covered in your home. It kinda sucks but it is better now than after your warranty expires this repair would cost several hundred dollars.
Dec 23, 2006 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Zenith Z50PX2D 50 in. Plasma HDTV Logo
51 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
