Question about Whirlpool RS675 Electric Kitchen Range
Whirlpool Oven Model # RS675PVGB10 will not heat
I tried to use my oven tonight and the normal preheat cycle did not work, nor did the broil or clean cycle. I here it click on but the electric burner does not get hot. I tried to turn it off and wait 30 seconds to turn the power back on , but that did not help. Do you have and suggestions?
  • 1 more comment
  • dreed2001 Sep 11, 2008
    I keep trying to log on to use your premoim service and the server is busy, How do I get to the thermostat in the back, I dont see how I can just slide the oven out. I could send you a picure but the it exceeds the size limitations. I need a document or manual that shows me how to get to it. not just someone some slide your oven out. Can someone please help me!
  • dreed2001 Sep 15, 2008
    I need additional help with this model, again can someone please send me a drawing, manual or something that tells me how to get to the back of this oven!
  • dreed2001 Sep 16, 2008
    I installed the thermal fuse as suggested and the oven will still not come on, I really need some help!!!!
    Scholar:
  • 163 Answers
Click an below . Page contains usefull troubleshooting tips
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN
Posted on Sep 15, 2008
    Genius:
  • 1,665 Answers
Enter model number at search tab and click SEARCH
You will find parts availability info for your oven
    Genius:
  • 2,035 Answers
For that information you need to have a service manual which available in this link :
http://www.appliancerepair.net/cgi-bin/purchase.pl?cart=---cart---&function=send&page=oven.htm
Good luck...
    Master:
  • 505 Answers
All i can say last time i work with a stove it was loose wiring . how ever could be the burner . just a suggestion. http://www.fixya.com/support/t356355-jenn_air_jds9860aap_control_panel__.aspx
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
Oven does not heat
This clicking sound.. If it is coming from the control panel area could be indicative of a relay that is malfunctioning.
For giggles try the oven on just broil. See if the upper element comes on and stays on, or if it too shuts down.
If it stays on then you most likely have a bad control board.
If it shuts off like the bake element and does not come back on, I would carefully inspect your power cord and cord connections as well as the range outlet.
Jun 16, 2010 | Kitchen Ranges
Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Dec 17, 2008 | Whirlpool RBS305PDS Electric Single Oven
    Electric Oven Won't Heat
    Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
    Jul 12, 2007 | Whirlpool RBS275PD Electric Single Oven
    Whirlpool RS675 Electric Kitchen Range Logo
    362 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
