Question about Garland H283 Gas Kitchen Range
Burn marks on pot and pans
Our Garland H283 is putting black sut on the bottoms of all our pots and pans. it does not smell and comes off easily, but it is really messy?? What is the problem. Also, I cooked steaks in the broiler the other day and the grittle turned black, will this always happen??
Our stove is new and we are just learning.
Just got a Garland 6 burner stove w/single oven. It was Natural gas need to convert to propane. Need supplier for conversion kit
Posted on Nov 21, 2008
How to clean cast iron both pots and pans
Don't..... just rinse with hot water and dry them, the blackening is otherwise known as "seasoning" and protects it from rusting, left to soak or washing with soapy water will rust the cast iron...... if this happens you need to remove as much rust as possible by scrubbing with salt and a cut (half) potato, then wiping with vegetable oil and "seasoning" in a hot oven (do this a few times, the oil will evaporate and bake-on a protective film) think of the edges of your favourite roasting pan....... well used/cared for cast iron will almost certainly look totally black.
Jun 24, 2014 | Lodge Cast Iron Chef John Folses Cast Iron...
Gas odor and turns my pans black
Sometimes theres too much air in the line. A better connection from tank to stove may help, or your running low on propane. Try cleaning the burners with an old toothbrush removing built up sut. Your flame should burn blue, not yellow. Hope it helps!
Sep 16, 2012 | Tappan Ovens
How tp clean black soot off bottom of turkey pot
If you are cooking with propane or natural gas, you may need a new regulator for your range, the black soot is most likely too much gas being used to make the flame. But, as for the soot on the bottom of your pans, try letting the pan soak in a mixture of baking soda and water, then attack it with a brillo pad. Hope this helps!
Apr 10, 2012 | Kitchen Ranges
Burnt bottom of large cast iron pot very discoloured and a certain taste seems to affect the food
Hi, Most microwaves do not allow you to put metal pot or pan in side. If sparks are coming off of pots do not use any more. You should be using proper microwave safe ware. Good luck.
Jun 20, 2011 | Microwave Ovens
Whenever I cook cream soups in my stainless steel pots, they burn on the bottom. I watch them very closely and just have the heat on medium, but they always seem to burn. I recently bought a glass pot to...
I'm assuming this is an electric stove, since that's what the picure shows. Most electric stoves turn the heating element on and off to regulate the temperature. On high the element is on almost all the time, on low it's off most of the time. The problem is that when it's on, it's on at full power, and sometimes this is enough to scorch things like milk based creme soups.
You can do two things:
First, try using a double boiler. This will put water in the lower pan and help keep the heat lower than with a regular pan. You could also try to find a pan with a very thick bottom, and try that. It might work better.
Sep 13, 2009 | Frigidaire 31 in. GLEC30S8 Electric...
I burned potato soup in my Le Creuset dutch oven.
Go buy a scraper for a ceramic hob and a can of barbeque or oven cleaner.
Spray the cleaner on and leave it for 15 minutes put on a pair of rubber gloves and use the scraper to break the surface of the burnt on stuff.
Make sure you keep the blade of the scraper as flat as possible to the surface of the pot.
Once you have scored some of the surface spry on some more cleaner and repeat the process
I clean off burnt casserole dishes using that method
Jun 20, 2009 | Le Creuset Q9500.67 Electric Kettle
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Mar 04, 2009 | Garland H283 Gas Kitchen Range
Black Garland H283 convert to Electric ignition?
Is there a kit to convert an older Garland 6 burner, double oven, griddle and salamander to electronic gas ignition?
Sep 25, 2008 | Garland H283 Gas Kitchen Range
Garland H283
contact hobart in raleigh.1-800-562-9499
Oct 28, 2007 | Garland H283 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
460 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
