Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Side by side not getting cold
My prob. is a Kenmore side by side. The freezer is fine. The refrigerator is @ 60 degrees and I cannot get it regulated. It is a no-defrost side by side. It is over 8 years old and we have a model listed as 71974107
  • 943 Answers
Hi. Thanks for The Question.Did You Check, The Fan in the freezer. Check that. Also Frost Build Up In Freezer. Also Pull Fridge From Wall Remove The Back Panel. Clean All Coils Thanks The Appliance Doc
Posted on Oct 03, 2008
Kenmore 106 56703500 Freeze is cold refrigerator is not
The problem could be an intermittently defective temperature control.
May 16, 2014 | Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
I have a Frigidaire side by side, 32 or 33 cc. The cold side is running 60 degrees, but the freezer side is fine. Any suggestions? Kim
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Refrigerators
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
Freezer works but cooler isn't cold
Try unscrewing the light, bulb mine did the same thing I couldnt figure it out. It turned out to be the light switch! Everything is fine now.
Aug 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge does not get cold
sounds like the internal fan is not working ,and on the same circuit as the dispenser.
I assume the tray is full of ice but not dispensing.
you likely have a failure at the circuit junction splitter board.
its just a board with a bunch of wires connected , usually in the rear .
Jun 04, 2008 | Kenmore 57029 Side by Side Refrigerator
Frezzer is fine but fridge is warm
See if cold air is coming out of the air diffuser top-back freezer side of fridge. A common problem is a bad air diffuser assembly. Sometimes it may freeze closed and break when it tries to cycle. The freezer usually works fine.
Aug 05, 2007 | Kenmore 53602 / 53604 / 53609 Side by Side...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
