Question about Canon PIXMA iP1600 Printer
Cartradge installed wrong
I have a ip 1600. Evertime I try to print it says, ink cartradge installed wrong. I have reinstalled them several times and it still says it. they are installed correctly
    Scholar:
  • 65 Answers
The cartridge could be bad. Try some others if they don't work then the printer is bad. I have a Canon Pixma MX300 and it seems it could be very easy to not get them seated completely.
Make sure each cartridge is completely horizontal with the table/surface it's on. If it's leaning toward you slightly it is probably not seated all the way.
The cartridges look similar to mine. You put them in the slot and push back and up until they pop into place.
Posted on Sep 05, 2008
Print Blank Pages not print by ink cartradge full
Here's a solution to your printer problem ;
Press the Ink button -> Test Print -> then choose Print Quality -> the printer will then go through and print a series of small squares in each of the four colors in the shape of parallelograms. If you see any gaps in parallelograms then you will be asked asked to clean the cartridge, do so. -> Just keep repeating process until there are no gaps
Then I did an Alignment check right after the cleaning through pretty much same process:
Press Ink button-> Test Print -> then choose Alignment-> and make sure the patterns match to the closest number
In Case You Still Need Online Help For Brother Printer,Then I Suggest You Follow Us For :Brother Printer Support
Sep 14, 2012 | Brother Ink for Dcp145c Lc-980
Both lights on printer flashing
If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
Aug 20, 2008 | Canon PIXMA iP1600 Printer
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
Feb 10, 2011 | Canon PIXMA iP1600 Printer
Printer does not print even after driver was reinstalled. Followed instructions, computer recognizes hardware during driver installation, installed fine but when trying to print anything it does nothing....
You have to change the USB cable of your printer, and it will solve your problem,
On the computer side, you have to check the properties of the printer, (Ports) it should be USB001 Go to printers , Select HP D4360>Properties>Ports if you still find any problem, Remove the whole software from the computer, disconnect the printer, restart your laptop and when the windows boots it should find the printer>click cancel and run the setup again, follow the on-screen instruction you will be able to install printer properly Make sure you don't have printer installed already (HP D4360 only),
If you require more assistance, feel free to reply to this post,
Regards, BA
Jan 15, 2011 | HP D4360 DeskJet Printer InkJet
Hi, I have a Canon PIXMA iP 1600 printer. Recently, I started to get a message that says: The waste ink absorber is almost full. Press the printer's RESUME button to restart ...
I have a Cannon PIXMA ip 1600 printer. Recently, I am getting a message that says: The waste ink absorver is almost full. Press the printer's resume button to restart printing. What is this ? How to solve this problem ?
Jun 15, 2009 | Office Equipment & Supplies
Printing wrong color
bad ink, try with original cardridge or use a profiler.
Feb 04, 2009 | Canon PIXMA iP1600 Printer
Cyan not printing,
PURCHASE A NEW CARTRADGE OF GO ONLINE
CANON 850i WILL NOT PRINT IN CYAN
SEE IF ANYONE ELSE HAS THAT PROBLEM AND HOW THEY SOVLED IT
ROD
Feb 02, 2009 | Canon i850 InkJet Photo Printer
How to put a ink cartridge in a Canon i850?
LIFT THE FRONT COVER UP , GIVE THE PRINTER SOME TIME AND THE PRINT HEADS SHOULD GO TO THE CENTER OR RIGHT OR LEFT MARGIN PUSH IN AND DOWN.
----------------------VERY IMPOTANT-----------------------------
I THINK NEW CARTRADGES INSIDE THE PACKAGING HAS INSTALL INSTRUCTIONS INSIDE THE BOX WHEN YOU BUY IT FROM CANON INK CARTRADGE, OTHER BRANDS MAY DO THAT, IF NOT SURE OPEN BOX LOOK INSIDE AND SEE IF THERE IS INSTRUCTION ON HOW TO INSTALL NEW PRINT CARTRADGE
ROD
Jan 06, 2009 | Canon i850 InkJet Photo Printer
Printer Pixma IP 1600
Verify your ink cartridges have the 'Tape: removed from the top of the cartridge.
IF the tape has not been removed a vacuum is present in the cartridge and it will not allow the ink to flow smoothly.
Also try a few cleaning cycles.
Feb 09, 2008 | Canon PIXMA iP1600 Printer
Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Aug 13, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
old marine
old marine
