Question about LG WM0642H
Oe MESSAGE I had an OE message and twice drained the drain plug and cleaned the filter. There was a little lint but nothing clogging it. What else can I try before calling for repair?
  • blueeyed35 Sep 05, 2008
    This machine is only a year old. Could the drain hose on the back of the machine be clogged as well? How do I check it?
    Thanks for your help!
  • porsche917 Dec 14, 2008
    oe code
UNPLUG THE WASHER FIRST. Drain all of the water with the drain hose. Lay the washer on it's back (put something behind it so that it is not resting on the hose connections etc) it won't lay flat but that's okay. DO NOT TRY TO GET AWAY WITH BALANCING IT AGAINST THE WALL WHILE WORKING ON IT. THESE WASHERS ARE HEAVY AND YOU DON'T WANT TO DIE TRYING TO SAVE A FEW BUCKS! You do not need to take of the white plastic grid on the bottom you can reach everything through the hole in the middle. Right behind the black drain hose/filter is the pump. Disconnect the hoses and check each one for a clog. Disconnect wires (note the location of each wire) there are only a few. The pump is held in place with a little piece of plastic at the bottom and a couple screws where the filter is on the front. There are two pumps that can be removed easily with three screws each. Take one off and check that the fan is okay and nothing is jammed in it. Do the same with the other. If there is nothing visibly wrong then it may need a new pump. As with any self repair, if you are not confident with mechanical items do not attempt to do it yourself. When tilting the washer always have someone there to help.
Posted on Feb 14, 2009
    Scholar:
  • 55 Answers
Man, ngfam is really hoping for acceptance w/ the "give me the BEST rating before..." lol...
Posted on Sep 05, 2008
    Novelist:
  • 166 Answers
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
  • N Golan
    N Golan Sep 05, 2008
    Only one year old that means you are still under warranty and should get service free! Even if its a few days past they will help you for free! Thats what the warranty is for! To protect you! call in the morning!
    Bless you,
    ngafm
    please give me the best rating before you sign off!
Oe code. Will not drain. Steps to fix?
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
I am getting an OE code on my dishwasher
Hi
Daniel
Aug 24, 2011 | LG LDF6810ST Stainless Steel Built-in...
LG 1419LF My dishwasher stops during its cycle, it shows an error message: OE, there is 2 inches of water at the bottom of machine...Please help...
Hi
Daniel
Aug 04, 2011 | LG Dishwashers
LG WASHER STOPS BEFORE THE END OF THE CYCLE..OE IS THE ERROR MESSAGE ON THE SCEEN
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Feb 04, 2011 | Dishwashers
My LG is 5 years old and cannot complete a cycle error message OE. Can't find my handbook help please.
Hello
Kevin
Nov 08, 2010 | LG Washing Machines
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
I have an LG Tromm Washer that continures to display the OE message regardless of what I've done. THe filter in clean, I've dranined the water several times, and I've pulled out the drain hose from the...
It's actually a DE error code which stands for drain error. Pull the little basket out that's behind the small door on the lower left front (where the drain hose is) and look inside. The drain pump intake is about an inch in on the left. Make sure there's nothing in there like a paperclip or hair pin. If possible reach in and see if you can turn the impeller. If it won't move there's something in there if it will turn then the motor is probably bad.
Apr 20, 2008 | Washing Machines
LG WM0642H Logo
147 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
