Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Btd140 to btd141
Just wondering what parts do i need to change on the btd140 to convert it to a btd141 with the quick connect action.
  • ss8coyote Feb 21, 2009
    The BTD141 has new one hand operation
    when loading bits. Pull out the collar and
    it is ready to just push the bit in.
    The only diffence I noticed in the spec
    diagram appeared to be the collar...
    Would love to know if anyone has tried
    to swap it out and if this allows the 140
    to operate the same.
    Does anyone know the procedure for
    swapping the collar?
  • 2,176 Answers
You have me confused. Both of these tools have the quick release collar on the anvil. Exactly what are you trying to do. It appears from the schematics I just looked at that they are virtually identical in design. If you need more info I would suggest going to Makitatools.com and typing in your model number and downloading both breakdowns. Hope this helps
Posted on Dec 29, 2008
It's hard to lock the drill bit, and it's hard to change the speed 1-2-3. I sometime need to play with the forward and rewind push on the drill ti be able to change speed?
Put some WD-40 in the chuck and use the chuck key to loosen up the chuck. The speed switch is going bad too. Those parts are readily available and aren't too difficult to change yourself if you pay close attention to which terminal on the new switch the wires connect to.
Sep 24, 2014 | Makita LXT202 18V LXT 2 Pc. Cordless Combo...
Honda TMX 155 with a 6-volt system, can it be converted to a 12-volt system
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Converting to 12 volts
http://www.dynamoregulatorconversions.com/6-to-12v-conversion.php
https://terniehapjay.files.wordpress.com/2015/10/honda-tmx-service-manual-pdf.pdf
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Sep 22, 2012 | Honda Motorcycles
How to convert hub brake into disc brakes
Hi, Rakitha for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
disc brake conversion
TW200 Forum
Yamaha TW200 Service Manual
OEM parts for Yamaha
YAMAHA TW200E Owner Manual
Jun 03, 2012 | 2009 Yamaha TW200
How do you change the brushes, and do you do it.
there should be a back cover that needs to be removed to expose the brush ring, It would seem unusual to have them wear out so quick but take a look anyway.
Oct 25, 2010 | Makita 18V LXT Lithium - Ion Cordless...
Convert windmill to wind generator
You will need really high rpms to get the alternator to spin fast enough to produce a decent output, which would require a pulley system or a gearbox of some sort. I would suggest a direct drive to a DC motor then through a controller to storage batteries and then an inverter (assuming you want AC power).
Mar 10, 2017 | Kitchen Appliances - Others
Hitachi Charger convert to 230v from 110v how to
Hi mate,you need a step down/step up transformer,try e-bay they sell tons of them..50-100 AU$
Mar 03, 2009 | Makita 18V LXT Lithium - Ion Cordless...
Action script
I think you are use a Flash Decompiler to convert swf to .fla ...Yes this will convert only the animation part of the flash movie..but it neglects all the actionscript part of the flash file. Many flash content would be connected with an external XML file for functioning which is at backend and its not publicly accessible.
Dec 29, 2008 | Computers & Internet
Bit stuck in quick release chuck - makita btd142
What has happened is the hex part of the bit has twisted slightly making it hard to remove. What I would do if you are comfortable with partial disassembly is remove the quick release mechanish. There is a split ring that comes off first and then a washer and spring, next remove the outer collar and SMALL steel ball from side of chuck. I take a pick (dental tool) and push up or try and twist the stuck bit. Sometimes it takes while but usually this works. Let me know if I can try and help further.
Oct 12, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
289 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
