Question about Intertherm Heating & Cooling
I have an Intertherm wall heater, model number WR-2000-t. It has quit working. I have power to the unit so I suspect that it could be the switch. Are there parts available for this unit and where can I order them?
    Novelist:
  • 166 Answers
Discount Parts Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Posted on Sep 05, 2008
Intertherm lp gas furnace model number m6rl060a be no power to unit breaker ok
If you have recently changed your filter sometimes the door doesnt go back on right to depress the door switch. if you have power going to the unit the next place in line is the door switch. it looks like a light switch in your refrigerator and the door must be in place properly to depress it all the way
Nov 30, 2014 | Intertherm Heating & Cooling
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
Remotes suddlenly quit working and the wall switch
sounds like you had a power spike
need to check code to see if its the same as what is on the remote
should be 5 numbers on the opener
where your wires hook up see the numbers and see if they are the same as what is on your remote
Feb 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Disconnect assembly has overheated and needs replacement. where can I find a new puul-out disconnect assembly for my intertherm furnace model FEH-015HA-03
Those parts are readily available. You can get them at intertherm.com or google hvacparts.com and have your model and serial number ready. You are talking about the pullout at the bottom left of the unit correct. If you have a breaker within six feet of the pullout you can remove it. But be very careful and turn off all power before you try.Rus
Dec 04, 2009 | Heating & Cooling
I have a Intertherm heating and air conditioner it is a Manufactured Home. The furnace model number is E2EB-017HA. When you flip the switch to heat and move the control arm up nothing happens. You can go...
When you turn the on/off switch to on you are turning on the "fan switch" and the blower motor is only coming on. When you turn the switch to cool and move the tempature control lever down you are turning on the air conditioner...So it sounds like your heater is not working. Is the heater electronic ignition or does it have a pilot? If it has a pilot the heater may not be working because the pilot is out and will need to be lit. If it is electronic ignition you will need to inspect the unit to determine what component is faulty. Could be the igniter,gas control valve,ect. Verify that gas is not shut off to unit at line valve and gas control valve on unit.
Oct 07, 2009 | Intertherm Heating & Cooling
Need to replace part. Short-irratic off/on. Where can I get it?
theis is the safety swith that senses overheating. If the fanmotor cuts off and the heater elements don't, this switch will sense excessive heat and open the circuit for both the heater fan and the heater element(s). If it is "shorted" it is because it is cool and not needing to activate to interrupt the power. The problem I am having is that the switch opens prematurely after just a coule minutes of operation. the unit has to cool down befoe it wll cycle on again for just a few minutes.
Trying to find the part nubmer for the switch.
Apr 26, 2009 | Fahrenheat (FFH1614) Wall Mounted Panel...
Intertherm ac/heater in a mobile home shuts off and won't come back on for quite a while. Then it runs fine for days, weeks, sometimes months. HELP
I am assuming it's an electric unit (most are). Sounds like there is a low voltage short somewhere. This could also be a thermostat problem as well. If it were a relay switch, it would not work at all because when they go bad, thats it they dont work anymore. There isn't an inbetween. I'm leaning more towards a low voltage short. Make sure that your low voltage wiring is tight and not loose. Be careful not to work on the unit with power to it.
Mar 14, 2009 | Heating & Cooling
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
222 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
