Question about Bunn NHB Coffee Maker
Bunn Coffee maker
My Bunn Coffee maker is slow to perk and leaks water from the bottem
Can you give me any pointers or tell me how to take3 it apart
  • Anonymous Sep 21, 2008
    it leaks profusely......
If you have water leaking from the bottom, simply contact BUNN. They will send you a replacement seal kit and your Coffee Maker will leak no more. This is a common problem with 'most' BUNN coffee makers.
Posted on May 30, 2009
  • 131 Answers
Your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Posted on Feb 11, 2009
4 Suggested Answers
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Posted on Sep 19, 2007
  • 5 Answers
SOURCE: Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Posted on May 23, 2008
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
My coffe maker leaks water all over the counter and has for a very long time, why? It's only about 3 yrs. old or less, I think and I am tired of it, I have to clean it up everyday and then add more water...
If you haven't used a replacement carafe, then it is probably a clog in the drip orifice, at the bottom of the basket. Note: don't put hot water in your coffee maker as it will perk faster and cause an overflow. Only use cold water. If you have replaced the carafe then it is probably the wrong size.
Feb 08, 2011 | Bunn B10 Coffee Maker
Bunn code date 145000 water leak took apart need
If you will call customer service, a seal repair kit can be sent to you which is successful 90-95 percent of the time in fixing the leak problem.
Mar 25, 2010 | Bunn 10 Cup Home Coffee Brewer
Leaking non commercial Bunn 12 cup coffee maker.
I will be happy to assist you with this issue if you would provide your model and date code which are located on the bottom of the unit.
Dec 30, 2009 | Bunn 10 Cup Home Coffee Brewer
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn perks coffee very slow?
This is generally an indication of a lime build-up in the water tubing. If you take off the sprayhead and insert the metal deliming tool into the water tubing all the way leaving out about 1-2 inches and twist it about 5-6 times, this should remove the lime deposits from the water tubing. Then flush out the machine with 2-3 decanters of water. If this doesn't fix the problem, then call customer service with the model and date code for further assistance.
Aug 01, 2009 | Bunn GR10 Coffee Maker
I have a BUNN VPS that leaks water when we make coffee. I have removed the top of the maker and watched, but I can not see the leak.
There is a significant amount of plumbing inside one of these. I think it will have to be taken apart to find the leak -- these leaks are very common and sometimes very difficult to stop (kinda like a roof leak).
Apr 21, 2009 | Bunn VPS Coffee Maker
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
Bunn NHB Coffee Maker Logo
638 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
