Question about Konica Minolta DiMAGE E500 Digital Camera
Is it necessary to load the battery (power supply) when the camera is connected to the computer via USB cable?
    Master:
  • 425 Answers
Yes. Please use the battery or dedicated AC adapter. For transferring large size of images, using AC adapter is recommended.
Posted on Sep 19, 2005
My Nikon S4000 (black) won't charge. I've tried plugging and unplugging the cable in the socket. I've made sure the cable is connected properly into the camera's port. I've tried charging via the computer...
Follow this order:
when plugging in the camera and then plugging into the compuer does the computer recognise it? If not this is either a bad cable, or not an active USB port, or something has gone wrong interanlly with the camera. Internal can be anything from bad voltage chip to bad battery. But some people have put the battery in backwards or with the positive terminal the wrong way. Double check that this has not happened, as anyone could have done it, unless you live alone. Try another computer and see if it recognises that camera if so the cable is good and you can continue to trouble shoot in other areas.
Mar 10, 2011 | Nikon Coolpix S4000 Digital Camera
My Nikon S4000 (red) won't charge. I've tried plugging and unplugging the cable in the socket. I've made sure the cable is connected properly into the camera's port. I've tried charging via the computer...
The battery itself won't charge in-camera like a cell phone-- you'd need to remove the battery and plug it into the supplied charger (EH-68P). You may have an ac adapter for the camera that basically would just be used to power the camera without a battery or for long periods of time without relying on the battery. It wouldn't be used to charge the camera.
When I attempt to download photos onto my laptop I either get a message saying the USB hub cannot take the power level required or there is no recognition at all. Any suggestions?
You might want to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 20, 2011 | Vivitar ViviCam 8400 Digital Camera
How to upload photos to a computer
Hi either direct from your camera via usb cable provided you have loaded the software that should come with the camera or via a card reader.
Dec 29, 2010 | Fuji Cameras
Unable to down load to pc using supplied usb cable. We have had our camera for approxomately 18months and up to now has worked fine.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sep 04, 2010 | Kodak Easyshare Z8612 IS Digital Camera
BATTERY DOES NOT CHARGE Received a "Vivitar T328" camera yesterday. Inserted the supplied battery and a new memory card into the camera and connected the camera via "USB" cable to the supplied charger....
How old is the battery? If the battery is refurbished or old it might just not charge anymore.
Also, do you have a separate charger for the battery? Many cameras do and that is how they charge, not when the battery is still in the camera.
Apr 09, 2010 | Vivitar ViviCam T328 Digital Camera
Camera will not upload photos to computer
Depending on the method you're using, this can usually be remedied in one of two ways:
  1. USB Cable: make sure your camera is turned off before connecting to the computer, and that the drivers for your camera have been loaded prior to connecting.
  2. Memory Card: SD or MMC card readers are becoming more std. on computers, or inexpensive card readers are available to connect via USB.
If you are experiencing difficulties with either of these, this may involve a problem with your USB port or the drivers your computer is using. Sometimes it's as simple as removing the driver which isn't working properly and re-installing it again. In most cases, you will need to install the driver without the USB device connected, so that after you have successfully loaded the driver, the computer will recognize your USB device properly.
Once again, make sure your camera is turned OFF when you connect it to your computer with the USB cable (of course, your computer needs to be turned on). Then, turn the camera on, and you should see the computer recognize the device.
Apr 01, 2010 | Kodak EasyShare Z760 Digital Camera
Can you trickle charge the Olympus FE-20 via the usb cable?
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Jul 02, 2009 | Olympus FE-20 Digital Camera
USB connection
Yes, the Olympus CB-USB-4 (p/n 200 776) cable is necessary to connect your camera to the computer. This cable is supplied with your camera.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Konica Minolta DiMAGE E500 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
