Question about Riso RZ220 Duplicator
Riso RZ 220UI
Original is on platin, print side down. Copies come out blank. Fresh cartridge is in place. Error "d04-534" is blinking. Manual says it could be wrong cartridge, or cartridge could be dirty. I checked both, to no avail.
Any help will be appreciated.
Thank you.
  • htiduj Sep 05, 2008
    I hope you can help. Thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Riso Master
  • 1,362 Answers
1-need to find out if image is on the drum, make a copy and stop it open and look is there toner on the drum itself? yes then the problem is with the Seperation
2-No, then the problem is with the Transfer
Posted on Sep 05, 2008
    New Friend:
Tengo un problema con mi rz 220 ui. me sale la mitad de la hoja nada mas, la otra mitad no marca la tinta, que puedo hacer ? estoy preocupado
Posted on Jan 14, 2013
Riso Rz 990U after printing few copies there are wrinkles on master. How to fix that?
the master should be scanned once with the number of copies being entered as the rest of the copies then are printed from the memory
Aug 22, 2015 | Office Equipment & Supplies
Riso RZ 220UI shows horizontal bars
you have to change the whole unit of your led light. the bar with all those led lights are attached or soldered. hope to be of help.
Jan 03, 2014 | Riso Office Equipment & Supplies
I need an instruction manual for the Riso RZ 200 EP machine. Can you help please?
go to www. riso.com/hk or www.ricoh-usa.com or www.2manuals.com or www.retrevo.com
sincerely. God bless you
May 09, 2012 | Office Equipment & Supplies
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
I have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Jan 20, 2010 | Riso RZ220 Duplicator
Color line along side of copies; doesn't always print; error message keeps blinking (no manual),
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
May 27, 2009 | Konica Minolta magicolor 2400 Laser...
RISO RZ200
if show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Apr 13, 2009 | Riso RZ220 Duplicator
Lexmark 4039 10r
I'm pretty sure this is a printer not a copier.
Take out the cartridge and turn it upside down, you will see a (Usually) green cylinder, does it have a ring of toner, or does it appear to have been scrathed ?
Take the copy and put it next to the drum, does the lines match? Then replace cartridge.
If not open back and take out fuser ( two screws for cover and two screws for fuser, are the rollers o.k? replace fuser.
Oct 02, 2007 | Riso RZ310 Duplicator
659 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
