Question about Canon DC220 DVD Camcorder
Edit and transfer to DVD
Please help me to transfer the recordings to my computer, edit it and copy to a dvd. I have not found any programs which would allow me to copy my mini dvd to my computer, edit and then make a new dvd to share my videos. I have Windows XP on a Sony computer with giga pocket and also have Windows Movie Maker.
Can you help?
Cathleen Michka
c.michka@sbcglobal.net
  • 1 more comment
  • davehilleary Nov 30, 2008
    While using Windows Movie Maker & when the camcorder is plugged in via USB cable & when you choose import from "digital video camera" the following error message appears. - "import video could not find a compatable digital video device verify that the digital video device is properly connected and turned on"
    All the correct camcorder instructions have been followed. Does anyone have a solution.
    Cheers
  • Anonymous Mar 28, 2009
    i can't transfer the data on to my computer for editing and the software that comes with it dosn't teach me how to work it
  • fotozzoom Apr 11, 2009
    cannot copy dvd movie to my computer
I use Handbrake ( http://handbrake.fr ) to turn the minidvd files into Mpeg4 files. I have a canon dc 220 and I hook it up to my computer with the supplied USB cable. I then copy the files onto my laptop and use Handbrake to convert them to the mpeg4 format.
Randall
Posted on Oct 03, 2008
I want downlod camcorder to my computer
Posted on Oct 04, 2008
Hitachi dz mv230a DVD CAM - can't copy video to computer (WXP Pro)
Make sure its pluged in to a powersource and try again, you should see the camera in my computer.
There might be fault in the camera.
May 18, 2008 | Hitachi DZ-MV230A DVD Camcorder
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
How to transfer Panasonic DMR-E80H recorded DVDs to computer
I have to agree with XELIAM regarding finishing the disk, under the DVD "FUNCTIONS" selection from the remote. I also use the SLYSOFT products to transfer my videos to what ever other mode of video I wish to have, whether iPOD (MP4), or DIVX (AVI) or loads of other options. Slysoft makes a GREAT product
Dec 04, 2009 | Panasonic DMR-E80H DVD Recorder
How do i edit a dvd? i copied a movie from tv but it ran over and dvd copied part of another movie.how do i remove it
if u have recorded using dvd recorder then u need to use Pinnacle video maker or sony vegas to cut and edit ur movie
Jul 09, 2009 | Ahead Software Nero 7 Essentials Suite...
I recently got a Philips DVD Recorder/VCR: Model No. DVDR3510V/05; Serial No. 0751 010790. I have recorded a VCR tape and would like to transfer this to a DVD±R disc. Can you tell me how to delete...
After you transfer the data to the DVD, you can use a DVD editing program like the DVD remake found on this link
http://www.afterdawn.com/guides/archive/dvdremake_tutorial.cfm
and you can edit out all of the commercials
let me know if you have further questions with this
Oct 07, 2008 | Philips Televison & Video
Copying a recorded file so I can edit it in iMovie on my computer please
I'm pretty sure that iMovie can cope with lots of different file formats. If you can burn the file onto a DVD and get the file off the DVD onto your computer's hard drive I think iMovie will cope with the rest. I know I have worked on Imovie in the past with DV files from my camera, but I'm sure that something like an mpeg file or a mp4 file will work too. What are the file options for recording from the HDD to disc?
Aug 10, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Copying disc of videocanea
With a combo machine you are usually stuck making another disk from your VHS tape-unless yours has a hard drive. Or you could make a copy with your computer DVD recorder-much faster by the way.
I don't know about adding music and naration it all depends on what your manual says your machine can do.
Jun 21, 2008 | Samsung DVD-VR357
Transferring video files to a computer for further editing
First you have to make sure they are NOT recording in VR mode.
But i would say it sounds like they have not finalized the discs.
To get them onto your PC you would need to convert/cut them with something like total video converter. If you want to edit more than just cutting you would need another program for that.
May 14, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
No edit
have you finalized the disc before trying to play it in another player?
Feb 20, 2008 | Aspire Digital AD-8091 DVD Recorder
Canon DC220 DVD Camcorder Logo
539 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
