Question about Olympus C-315 Zoom Digital Camera
Memory card every time i try to turn my camera on WRITE PROTECT keeps appearing on the screen ..can u help me?
    President:
  • 919 Answers
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect image and the card can be used again.
Posted on Dec 17, 2008
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Every time I turn on my camera a message appears on the screen that says "write protect". What is "write protect" and how do I get rid of the message?
1) It could be your camera has write protect switched on. Go through your camera's menu and look for picture protect and remove it.
2) Your SD card could be write protected. Take out the SD card and check, there's probably a sliding notch on the left hand side, move the to write enable.
Jun 27, 2010 | Olympus FE-190 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
Nov 18, 2008 | Canon PowerShot S51S Digital Camera
AIPTEK IS-DV2
First check the memory card to see if the lock tab is in the UNLOCK position. On the top left of the memory card is a slide the moves up and down. The slide should be in the up position for it to be unlocked. A locked memory card could cause the camera to read a CARD PROTECT error message.
If you still receive an error message, verify that you are inserting the card correctly so that the spring locks in as you fully insert it. When performed correctly an Icon will appear in the lower right hand corner of the LCD screen. Also try inserting the card while the camera is on.
The memory card may also need to be formatted through the camera’s settings-- Note: Formatting will delete all files, so be sure to transfer any important files to your computer before doing so
To Format: Insert the memory card into the camera and press the mode button to get to the mode screen. Enter into Tools/SETTINGS and find FORMAT. Once you select format you will receive a YES or NO option. Select YES and you will see a FORMATTING message. Once the formatting is complete, see if the camera reads the card and functions properly
Jul 08, 2008 | Aiptek IS-DV2 Camcorder
How to unlock the memory card of my digimax S500/S600
Your card is protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 24, 2008 | Samsung Digimax S500 Digital Camera
Memory Card
Check to see if the lock tab has been put in the lock position. If yes then slide to the unlock position.
May 08, 2008 | Cameras
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
My 3935 keeps erasing memory cards. All of the sudden, you get a white screen and the camera won't function until you remove the card. This has happened twice; both were Kodak 128 SD. The first time,...
i know it's not solving your problem, but at least it stop from happening again... You can protect images/video clips from being accidentally erased using the protect function in the Playback menu... see also: http://www.fixya.com/BrowseManual.aspx?prdid=218406&mpgid=843814&hlt=erase
Nov 21, 2005 | Vivitar ViviCam 3935 Digital Camera
Cameras Logo
52 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
