Question about Pioneer Audio Players & Recorders
I just bought some pioneer ts-w305c subs from some guy in canada and one of them is sounds distorted< when barely playin it buzzes can u help me?
  • 4,234 Answers
This could be either the speaker that is blown and making the noise or part of the amplifier being smoked causing distortion that sounds like a blown speaker. WIthout taking it apart and looking at waveforms on an oscilloscope, I can't tell you which is the problem. I'd ask a local shop to test it for you or if you can, exchange the actual speakers between the two. IF the problem stays with the bad box, the problem is with the amp, if the good speaker works OK in the "bad box" then the speaker is blown.
Keep us posted.
Dan
Posted on Sep 05, 2008
  • ABRsvcs Sep 05, 2008
    Joshua,
    I'm not really sure what you expected from this site. Can you explain why you rated this as a "Thanks for trying"? I'd like to know. I have provided a few things for you to try as I can not see nor hear the problem. You need to be my eyes and ears. I'd like to help further, but without additional info, there is little I can do. Lets help each other to resolve your problem.
    Thanks,
    Dan
PROBLEM WITH SUB WORKING ON A PIONEER VSXAX5I RECIEVER
The problem is in the powered sub, the buzzing sound is caused by one or more defective audio output ic's that drive the subwoofer directly, service is the only option to remedy the situation.
Apr 14, 2012 | Pioneer Audio Players & Recorders
What amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Jan 30, 2012 | Pioneer TS-W307D4 Car Subwoofer
Ive bought 2 of them . after 1 week they both sound distorted. only running a pioneer 760 amp to itthere is nothing wrong with the wiring
If they were OK at first, you maybe put too much power into them and fried the voice coil. If so, it is fatal and they would need to be re-coned.
Jul 26, 2009 | Pioneer TS-SWX310 Car Subwoofer
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My amp wont power both subs the same
you most likely mess up you wiring... im not sure what ohm resistance your subs are, but if its 2ohm or 4ohm you wire straight foreward one sub all positive wires to left positive, all negitive to left negitive, and the same with sub 2 to the right terminal. BUT if your subs are 8ohm then wire it with all positives from both subs to LEFT positive and wire all negitive wires to RIGHT negitive... and see if that helps and good luck!
Jan 12, 2009 | Pioneer TS-SWX310 Car Subwoofer
Terrible distortion from Sony Dav-x10 2.1 subwoofer
its not broken just turn the cut off frequency to level and the volume of the sub lil bit higher and it should work fine.
Nov 11, 2008 | Sony SA-W305 Subwoofer
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Apr 08, 2008 | Pioneer VSX-454 Receiver
2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Mar 27, 2008 | Pioneer TS-W301R Car Subwoofer
Pioneer ts w33c
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Mar 08, 2007 | Pioneer TS-W33C Car Subwoofer
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
