Need operater manual for 1380 watt 11.5 amp jebb air home microwave w110 series. part number 224-0613(6) just need manual for it i can print out lost mine moving.
They are usually at the rear where the power lead goes in. This will state the maker, the address, the voltage and watts, the model number and serial number. That is a statutory requirement. In some circumstances they are in the door frame rebate but not so common where heat is involved.
Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
I am not sure what you mean. If you are asking how much power it draws in Amps, that is printed on the rear panel as Watts. It depends on your mains voltage.
Your microwave oven is 700 watts. Its printed on front of the owner's manual. If you no longer have an owner's manual, you can go to managemylife.com and download or print a copy for FREE. Just type in the model number you provided under the "Manuals" link. Your manual is listed in .pdf (Adobe) format. I hope this help you.
