Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-51HW40 6 blinks
Hi:
I have a kp-51hw40 that shuts off while we were watching. The TV will not turn back on and the TIMER/Standby led keeps giving "6 blinks". Do you have any infomation that might help me fix it? Thanks.
Kim
  • 60 Answers
Hi Yeooow,
I guess you read the fix for my set wth the six-blink error. If not, here's the link:
http://www.fixya.com/support/t647530-tv_couldnt_turn_no_picture
My set is a KP-53HS30, chassis number P65A-A.
I found a bulged capacitor on the "G" power supply board and replaced the components associated with that circuit (6-volt regulator). If your set has the P65A chassis, I'd be happy to e-mail you the service manual I have, if it will help.
-Dan
Posted on Sep 06, 2008
Hi There... I have a sony kp-51hw40 and when I turn it on a green screen appears, then turns off and the standby indicator light begins to blink in sequence of 6 times each. can you help please or make...
The 6 blinks is happening be cause the set has lost high voltage and shut down due to the green CRT needing replacement. You should be able to get a replacement Green CRT from www.tvrepairworld.com
Jun 25, 2011 | Sony KP-51HW40 51" Rear Projection...
Screen turned orange, heard a sizzle sound tv
A capacitor has burned out. It may be on the motherboard or power supply.
Jul 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
Aug 19, 2008 | Sony KP-61V80 TV
Sony TV KP-51HW40 solid red lights [timer/standby+stereo]
if the main board by chance got wet you will need to use a blow drier to try and dry it out..it may already be beyond fixing if water goi into it
Aug 17, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Kp-51hw40 problem
your blue tube is shorted unplug blue crt board see if set comes on and stays on!
Nov 07, 2007 | Sony KP-51HW40 51" Rear Projection...
My sony KP-51HW40 TV shuts off
the eight blinks indicates you have a high voltage error. you will need to replace the d board. the part number is A-1348-038-A.
Oct 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
326 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
