The TV will not turn on. It has power, the orange power light is on. But the on switch and the remote will not turn it on. There's no picture - nothing!
My solution--bought a Samsung. Seriously!
Also, I read somewhere that it may be the powerboard and that the replacement may not be too difficult. Good luck~
I have a Vizio 37in hdtv i had the same problum i had to buy the Vizio Main board and put that in it and the TV come right on
My vixio l37 will not turn on neither with the remote nor the power unit ,need some solutions
SOURCE: No power -- TV will not turn on
This could be the power supply baord / Bad Caps/ They will be puffed up..
Or if the inverter board is bad** Inverter board lights the backlights.
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
orange power logo is on but power button and remote will not turn tv on
For two days our L37 shut off all by it self. We'd turn it back on only for it to happen again a few minutes later. This morning we were unable to turn it on at all.
Our L37 would not turn on this morning. Tried the remote and the push button. A green LED that usually indicates that the tv is on is always on now.
the green indicator light powers on, but no sound or pic
My Vizio L37 TV will not turn on. It has power, the orange power light is on I change the power supply unit that wasn't it. what's next
My Vizio L37 TV will not turn on. It has power, the orange power light is on, i change the power supply unit, that wasn't the problem what's next
I have power (DC Power LED is orange), but cannot turn set on (DC power LED green) with either the button on the set or the button on the remote.
Mine too was turning itself off periodically, then ultimately went off and will not turn back on. The orange light is on, but nothing else.
