Question about Bulova Marine Star 90B50 Wrist Watch
Alain Silverstein Krono Bauhaus Automatic watch w/Rubber Strap
I rec'd this watch as gift, but I've misplaced the operating manual. Any ideas were I can get a replacement?
Why my movado watch stop since it is automatic? im using it everyday and suddenly stop
How active are you? How long have you had the watch and have you contacted Movado to trouble shoot.
Oct 01, 2014 | Movado Watch, Mens Automatic Se Extreme...
Sector 130 watch strap
Hey! Just go to this website and tell you how to adjust a rubber band watch and how to replace it!
www.watchbandsonline.com/qanda.asp
Hope it helped! ^-^
Sep 17, 2012 | Sector Expander 130 Chronograph Alarm Mens...
Need an owner's manual for the citizen aqualand watch model jv0030-19F Anniversary Edition Orange Strap
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
or
Go to "citizen.com" and click on "watch finder".
Put your watch model into the search box on the left and click on
"search".
Click on the watch to view details.
On the right is a small menu, click on "get technical info"
On the right you you will see a list of instructions you can download.
Mar 12, 2011 | Citizen JV003019F EcoDrive Aqualand Strap,...
Replacement watch band
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Mar 30, 2010 | Oakley Watches
How do i maintain the color of the rubber strap ?
Replacement is likely to be the only answer. Perhapos you could try another style of strap from your local watch shop.
Jan 21, 2010 | Bvlgari Rubber Band Watch
Where can I download instruction manual?
Just click this link and ask there for a user manual:
http://www.a-silberstein.fr/us/accueil.htm
Here you can download also:
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ALAIN%20SILBERSTEIN
Good luck:
Regards:
VOTIT
Jun 27, 2009 | Watches
Indiglo button kills watch function
I have the same problem with my watch. I replaced the ML-2016 battery myself. (which I found at Walmart) But when I press the iniglo button, it just stops the clock and I have to press the start/split button to get it to resume. No idea how to get the problem resolved
Aug 19, 2008 | Timex 5J261 Solar Powered Ironman...
Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
Replacement Black Rubber Strap
Your local jeweller should be able to order t for you.
Mar 27, 2007 | Hugo Boss Swing - Ladies' Square Case...
Bulova Marine Star 90B50 Wrist Watch Logo
397 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
