Question about Canon PIXMA iP90 Mobile Printer
Figuring how to install new print head in my Canon iP90 printer
Hi,  Just can't quite figure out how to remove and install a new print head.  The Canon online guide was of little help.  Thanks, Michael
The important point is moving the head to the left, or sliding it left or right, so you can actually SEE the LEVER. It is hidden otherwise and what appears to be the obvious lever on the top is the wrong lever. If you have pressed the correct lever the unit removes very easily. If it is hard and you cannot make progress chances are you have not found the correct LEVER!
Posted on May 04, 2009
  • 76 Answers
When you open the top cover, the carriage unit will mvoe to the middle of the unit. Once it is there hold the inks and move a bit to the left so you can see a grey lever. then the printhead and the inks will come up together. remove inks and replace head.
This should work for you
Posted on Oct 20, 2008
My ip90 won't turn on !! What can I do to fix myself??? Any help on this matter will be greatly appreciated..
Posted on Nov 16, 2008
My CaNON ip90 PRINTER SAYS "ERROR" WHEN TRYING TO
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Mar 08, 2011 | Canon PIXMA iP90 Mobile Printer
My Canon IP90 printer in printing blank paper
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaces.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new injet printer.
Jan 16, 2011 | Canon PIXMA iP90 InkJet Printer
My canon ip90 printer cartridges is stuck to the right of the printer. And the light keep flashing orange 5 times. Can someone please help me fix it.
LED blinking in Orange color 5 times = Print head is not installed properly or the print head has reached to the end of life.
May 29, 2010 | Canon PIXMA iP90 Mobile Printer
My new canon ip90 printer won't print anything goes through all the motions but no ink comes out. brand new cartridges in it?
Is the shipping cover still on the printhead? If it has been removed, wipe the printhead with a damp paper towel to see if the head is plugged. If ink is present on the towel, do a print head clean from the maintenance menu.
Oct 11, 2009 | Canon PIXMA iP90 Mobile Printer
Canon Pixma iP90 - Jagged text and lines
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Jun 02, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Color Inktank
May be time to replace the print heads as a new unit is quite pricey. Refurbished from canon is about $150.00, print heads are about $50.00
link
Apr 05, 2008 | Canon PIXMA iP90 InkJet Printer
Print head for canon ip90
There is a very easy fix for a Canon IP90 not printing either color or black. I just fixed mine a few minutes ago. Go to the local Dollar store and buy some nail polish remover. Then open up the printer, remove the ink cartridge(s) and put a few drops of nail polish remover in the hole that receives the ink. Works like a charm and fixed mine in just minutes. After inserting the polish remover (actually just Acetone with some glycerin) reinsert the ink cartridge and do a deep clean using the Canon utility from the Control Panel under "Printers > Properties > Maintenance (right click on the Printer icon in Control Panel to start)." You can also simply use acetone. Another trick is to remove the print head which holds the ink cartridges (although I could not figure out how to do this but it's doable) then put a paper towel soaked with distilled water (tap water probably OK) in the microwave, heat the towel and quickly put the print head on the hot paper towel. As a last resort simply order a new print head from the Internet and replace the print head. I would presume it would come with instructions for removing the old print head.
Dec 29, 2007 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
1,800 people viewed this question
old marine
old marine
