Question about Kyocera FS-3900DN Laser Printer
Kyocera 3900DN Error Code
Hi there does anyone know what this code means?
Error.Power Off
F030:0075803
Any help would be greatly appreciated.
Thanks
    New Friend:
We almost bought a new printer on the strength of the comment from Joris Vanden Driessche. However, when I spoke with Kyocera support engineer over the phone I only mentioned F030 and he said that this error code is a network issue, not hardware. There was a pdf document stuck on the print queue causing this error. After deleting the job I then re-started the printer and all was fine again.
Once you get it working again make sure to update to the latest drivers and you should be fine.
Our model printer is FN-3820N.
Posted on Apr 30, 2014
    Problem Solver:
  • 14 Answers
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Posted on Sep 16, 2008
I have Kyocera FS-3900DN , it shows on the display error code (call service 6030:1022274) thanks
This problem is caused by a poor contact in the fuser connector terminals.
Check both sides of the connection (in the printer and fuser unit) In most cases we will find small pieces of paper inside printer connector causing poor contact between printer and fuser unit connector.
Hope i was of any help. If i was, please rate me.
Thank you.
PcSimples
Mar 14, 2011 | Kyocera FS-3900DN Laser Printer
Kyocera fs-3900dn showing 7410:0024216 error code what do I do
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Apr 15, 2010 | Kyocera FS-3900DN Laser Printer
HI My Kyocera FS-6020 comes up with the call service number 4200:0019564 number! does anyone know what this means thanks
This error code means that the Laser unit in the machine has failed and will need to be replaced.
Mar 24, 2009 | Kyocera FS-2000D Laser Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Error code 150:0000001
I don't have much experience with your model.I suggest you to contact other experts regarding this issue.
Aug 31, 2008 | Kyocera FS-3900DN Laser Printer
did the error came on after replacing tonercartridge ?
open the door at the left and push on the drum till you hear click, problem should be solved afterwards.
Jul 23, 2008 | Kyocera FS-3900DN Laser Printer
Error code:0150:0081084 anyone know this code and how to fix thanks
A firmware upgrade should solve the problem
download the file (i received one a year ago ftom Kyocera), put it on usb stick
power off the machine, installed the usb stick (at the back) and power on
after upgrade problem should be gone
Jul 17, 2008 | Kyocera FS-3900DN Laser Printer
Error code 7410: 0026060
7410 error
most likely you need to push the drum back till you hear click (drum at the left side at the prt)
Jul 10, 2008 | Kyocera FS-3900DN Laser Printer
FS-3900DN Error 0150:0000000
This error suggests eprom error the system firmware will need to but upgraded or reinstalled.
If it is new contact the store you purchased it from and tell them. If not contact Kyocera online and they will (or Should give you a dealer in your area)
Thanks J
Jan 02, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900DN Laser Printer Logo
3,160 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
