Philips magnavox 9p5511c102
Sparks and sizzle come out of tube right front of the large signal board this part has a thick red wire coming out the top. any suggestions.
  • cos752 Sep 05, 2008
    i checked the part on the site and i dont think thats it. the part iam describing is further up on the board smaller grey tapered tube the red wire comes out of the top and i think plugs into the hv generator. thanx
  • cos752 Sep 07, 2008
    sorry it is the hv gen. i looked at the wrong picture,on the site you sggested ,after further cking i found the wire that goes in the gen. burnt on the end so i clipped it and reinstalled it not sure how much to strip or how far to put the wire in. but the tv seems to be fine no sizzle or arching. next any tips on cleaning the mirror? thanx for any help
  • 8,617 Answers
You need a new HV generator. The following site has them and they have a picture of it so you can see if thats the part youre referring to, I believe it is. Its listed under the flyback section and its called Phillips HV generator.
http://servicemanuals.vstore.ca/
Posted on Sep 05, 2008
  • Sonny Berry
    Sonny Berry Sep 05, 2008
    I would need to see a picture of what your describing. Can you post a picture of it?
  • Sonny Berry
    Sonny Berry Sep 07, 2008
    the best way is to just remove the shelf that slides in next to the tubes and then just reach up on the back wall and clean the mirror with a soft damp cloth ( NO WINDEX) then dry its a bit of a twist and reach but it can be accomplihed from the rear without dissassembling the unit.
Phillips Magnavox 9P5534C103 need to replace Ics
Check with TV repair.com who sells kits for most of these sets that come with all the needed parts and instructions---you might also look on You Tube who has video instructions for a lot.
This is a older set and the chips will either be on large board to left as seen from rear or to the far right side as seen from rear--the chips are soldered in STK-392-110 OR -120 CHIPS. I can give general instructions if know where they are and what number is printed on the front of them.
Oct 23, 2012 | Philips Televison & Video
MAGNAVOX DOES NOT TURN ON
chirp is short in power supply/sweep board===usually one in middle with large red wired black transformer.
Aug 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
I am going to resolder the flyback, but what is? and where is the small signal board?? And would that need to be replaced or repaired?
I am attaching a picture of the flyback whicch is the large transformer which is on the far left side and has the thick red wire coming out its top. The small signal board is the large green board on the right side with all of the inputs on it. The small signal board is a sensitive board and requires professional tools (Chipper Check interface )to diagnose and repair. But the flybacks are famous for failing. the flyback is circled in the picslinteriors_15.jpg
Jul 24, 2011 | RCA R52WH73 Projection Television
It has an electric arc in the back an makes a cracking noise
the high voltage runs the picture tubes. you have a bad high voltage transformer (large signal board) or something wrong with the anode wires (big red ones) or could be a bad tube. this has 30,000 volts so be careful or call a Pro.
Sep 09, 2010 | Philips 60PW9363 60" Rear Projection...
Magnavox LCD HDTV starts on its own since last few months and sometimes it changes channel on its own. This problem happens intermittently and really apprecaite fix for this. This TV is 15 months old.
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
Sep 08, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox sizzle
can you reply to this same post with the model number of your set and I will assist you with the problem.
Sep 04, 2008 | Televison & Video
Hi again!!!
The RCA jacks should be near the signal board. The vertical will be on the same board as the Flyback which Is a large transformer with the large red wires coming out of it. You shold be able to remove the screws in the chassis and slide the chassis out and tip it up so you can see the under side of the boards.
Jun 01, 2008 | Philips Magnavox 51MP392H Rear Projection...
Color faded
9p6031c has similar problem. Can we just change out the color tubes??? Who has them and how inexpensive can we get them???
May 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
