Question about Dryers
We have a Maytag dryer that is 7 years old. It runs on propane. Recently it started getting louder during the drying cycle and it keeps getting louder. It sounds almost like a buzzing (NOT like the buzzer when it is done drying). Is there something I can do to fix it? What is causing it? Is there some sort of maintenance that should be done other than cleaning the lint trap?
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Does the noise continue for a few seconds after the dryer shuts off? No regular maintenance required. Also, please list model number (usually located behind door, near door switch.)
  • 1,543 Answers
Never saw a response to my clarification request, so I hope you have resolved you service question. Without further info, it's hard to give good advice, but you might look at the blower wheel to see if it is spinning loosly on the motor shaft. That will make noise, and usually continues for a few seconds after dryer shuts off.
Posted on Oct 05, 2008
Maytag dryer model number LDE840ACE squeaks during the drying cycle
That is probably a Wheel. More likely the wheel over the heater. I recently worked on one of these and posted a pictorial:
My Maytag dryer repairs
Jun 20, 2012 | Maytag Dryers
My Maytag Alliance gas dryer won't heat up at all. The dryer keeps running due to the temperature not changing. There is no heat at all. I ran out of propane - the dryer stopped during the cycle, the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 05, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
