Question about Whirlpool Duet GHW9150P Front Load Washer
Steady tone coming from ghw9150pw0
Wash cycle works fine, no alarm codes, no lights just a steady tone from the machine. The problem started yesterday, the tone was intermittant, I did not recognize any "alarm" pattern, now the tone is steady. I found the diagnostic test and all tests pass. The only way to get rid of the tone is to unplug the washer.
  • lamplighter3 Sep 05, 2008
    I'll give it a try, I ran a toothpick around the alarm option button, lucky I had my glasses on, saw the caution about holding in the button locks/unlocks the controls! Funny how it started, tone off, tone on, to me it almost sounded like a relay partially stuck, also, the humidity in the area is very high (Hanna approaches), I have "Dust Off", I'll try giving that a shot on the button but the control bd sounds like it might be it, I will keep you posted...tnx
  • Anonymous Mar 05, 2009
    fchfyyftufgtg tfylm lyg;tlmf fy y
    Genius:
  • 1,028 Answers
Could be problem in control bd not necessarily a problem with function but something in sound circuit ck for a sound control button on keypad it may say something like alarm volume or on off try holding it down after turning power on if you notice any change in volume or tone of sound shows you're on right track only thing is solution may mean new control bd
Posted on Sep 05, 2008
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
What does a steady flashing wash light mean?
pump all the water out and stop the wash cycle your on
open the door
then disconnect the mains supply for 10-15 mins
then turn it back on and hope the software fixes itself
otherwise there is an issue its detecting
like the door interlock is being detected as bad.,..
if the motor isnt running perhaps the motor brushes need replaced and this is the cause of the flashing wash light
and motor not running
i would check out the brushes have atleat 3/4 " on them
if not replace them
Dec 20, 2014 | Hotpoint WD440 Aquarius Washer/Dryer Combo
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Duet Washer Won't Start; Outlet Fine
How old are they & where did you get them from?
Jan 30, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Whirlpool washer model GHW9150PW0 control lock light on will not start a cycle
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Washing Machines
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing machine will not start wash - just beeps - key on display
Press and hold the Rinse Plus button and wait for the washer to start emitting a tone.
Whilst you are pressing and holding the Rinse Plus button, the tone increases in volume from low to high and then it briefly goes silent, before it starts over agian.
If you release the Rinse Plus button immediately the tone goes silent, then this will turn off the beeping.
If you don't release the Rinse Plus button in time, just continue to press and hold the button and the tone will cycle around again from low to high to silent.
Hope that helps.
Dec 07, 2008 | Audiovox Bosch 718 World Cellular Phone
Whirlpool Duet GHW9150P Front Load Washer Logo
200 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
