Question about EliteGroup P4VMM2 Motherboard
PC start when it feel like, not when I press the the starter
Motherboard P4VMM2 VIA VT8235....everytime when I start, it does not go...I have to wait some time when it feels like go...
I hope some one can help me
pereirabarreto@hotmail.com
  • Roberta Smith
    Roberta Smith May 11, 2010
    examine the capacitors.... any with swelled tops or leaking ?
    Robert
  • 3 Answers
Replace memory..we got the same problem and i just replaced my ram memory and it work. u can also check for a leaky capacitors if the first one will not work. thanks and good luck.
Posted on Sep 19, 2008
  • 781 Answers
Check M/board battery I believe the one in board has past its use by date and is flat you need a new one
Posted on Sep 05, 2008
Specifications only
CPU º Socket 478 for latest Intel Pentium 4 / Celeron processor
º FSB 533/400 MHz
º Support Hyper-Threading Technology CPU
CHIPSET º VIA® P4M266A & VT8235
º North Bridge: VIA® P4M266A
º South Bridge: VIA® VT8235
GRAPHICS º Integrated S3 ProSavage8 2D/3D Graphics
º Share Memory : 8/16/32MB
MEMORY º 2 x 184-pin DDR DIMM socket support up to 2 GB
º Support DDR266/200 DDR SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT º 1 x AGP 4X slot
º 3 x PCI slots
º 1 x CNR slot
STORAGE º Support by VIA® VT8235
• 4 x Ultra DMA133/100/66 devices
AUDIO º Realtek ALC655 6-Channel audio CODEC
º Compliant with AC'97 2.3 specification
LAN º VIA® VT6103 10/100 Mbps Fast Ethernet PHY
REAR PANEL I/O º 1 x PS/2 keyboard & PS/2 mouse connectors
º 4 x USB ports
º 1 x RJ45 LAN connector
º 1 x VGA port
º 1 x Parallel port (LPT)
º 1 x Serial port (COM1)
º 1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS º 1 x 20-pin ATX Power Supply Connector & 4-pin 12V Connector
º 1 x FDD connector supports one 360K~2.88MB FDD
º 2 x IDE connectors
º 1 x IrDA for SIR header
º 1 x SPDIF out header
º 1 x USB 2.0 header support additional 2 USB ports
º 1 x Front panel switch/LED header
º 1 x Front panel audio header
º CD in/ AUX in headers
º CPUFAN/CASFAN connectors
SYSTEM BIOS º Award BIOS with 2Mb Flash ROM
º Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
º Supports ACPI revision 1.0 specification
FORM FACTOR & LAYERS º Micro-ATX Size (244mm*244mm), 4 Layers
for more detail look at this site
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=436&CategoryID=1&MenuID=18&LanID=19
i hope this helpful
thank you for using fixya
Feb 06, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
Hi i have p4m266a elite group motherboard it o...
no funcionan los puertos USB cual es el problema que existe en la targeta? www.compucyb@hotmail.com
May 21, 2010 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
USB FRONTAL
Hello there:
can you please post this in english so all of us here at fixya can have the opprotunity to help you with your problem
Jun 21, 2009 | EliteGroup P4VMM2 Motherboard
Matching memory
Supported RAM Technology: DDR SDRAM
RAM Installed ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600.
If you have already replace it and its working good. not to worry about that.
Nov 30, 2008 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Version mother board?
This should be the drivers for 90% of the P4M Boards .
http://drivers.softpedia.com/get/MOTHERBOARD/Others/Via-VT8231-VT8233-VT8235-VT8237-Motherboard-36.shtml
Oct 16, 2008 | EliteGroup P4VMM2 Motherboard
Matsonic ms9158e+ audio driver iwant to free download for my computer
Sound is VIA AC'97 Enhanced Audio Controller (WDM) on VIA VT8235 chip. I couldn't use one from Matsonic either, because there's nowhere to download it from, so I used one from ECS P4VMM2(V1.3): 8235_350b (VIA AC'97 Audio Codec Sound Driver) preXP, and worked like a charm.
Sep 16, 2008 | Matsonic MS9158E+ Motherboard
Need help for sound card driver!!!
Try reinstalling both winamp & direct x.
Does this fix the problem?
Aug 02, 2008 | EliteGroup P4VMM2 Motherboard
VIA VT8235 board driver
yes you down load VIA VT8235 motherboard Driver go to
drivercollection.com
Apr 13, 2008 | Intel Motherboard
VIDEO CONTROLLER OF VIA BOARD
Try this site:
The download button is to the right of, Via VT8231/VT8233/VT8235/VT8237 Motherboard 3.6 driver.
Good Luck & kind Regards
Thanks for using FixYa...
Feb 29, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
