I have an Olympus Camedia Digital Photo Printer P-10, which I've owned for 2-3 years. This is the first time the ribbon needed to be replaced when I still had many sheets of photo paper left (my paper tray is full!). Does this mean the ribbon cartridge was faulty?
According to Olympus the 10-year old model P-10 Digital Photo Printer only supports Windows 98/ME/2000/XP and specifically says that it will not function with Windows 7 32-bit or 64-bit.
If you are running Windows 7 Professional, you can install XP Mode (free from Microsoft) and then install the P-10 within Windows XP to use it that way.
Firstly check your charger. I was having problems with my batteries packing up after about 1 hours use. Now I only charge 2 at a time (its a 4 battery charger) and the problem is no more. There is a limited life on batteries, check how old they are and if you've had them more than 3 or 4 years, I suggest you buy replacements. John
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus CR-V3 long-life lithium batteries (LB-01) will provide approximately 500 shots. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times.
The battery life of AA alkaline batteries varies according to the manufacturer and power rating. Alkaline batteries can provide up to 100 shots with typical usage. Olympus NiMH batteries (B-01 4PE) provide approximately 250 shots per charge and can be recharged 300 to 500 times. Olympus recommends the use of CR-3V batteries or NiMH batteries. Olympus sells an NiMH Battery set which includes a charger and set of 4-NiMH batteries. You can purchase this through Olympus dealers or through the Olympus Emporium (www.olympusamerica.com/store).
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times. Olympus recommends the use of CR-3V litium battery packs or NiMH rechargeable batteries. Do not use alkaline batteries unless it is absolutely necessary.
