AEG L12700ViT Front Load All-in-One Washer / Dryer
Problem for AEG L12700ViT Front Load All-in-One Washer / Dryer
Door Seal
By tan208 on Sep 04, 2008
The door seal of the l12700vit AEG washing machine needs to be exchanged as it s completely mouldy. is this something I can attempt doing myself or do I need to call a pro?
Best Solution
posted on Sep 05, 2008
Helpful)
tresilla
Rank: Guru  AEG Expert
Rating: 87%, 1597 votes
not too bad a job
turn off mains. undo clamp that holds door boot to cabinet and peel off the boot.
the seal is then held onto the tub either by a large circular spring or maybe a clamp with a screw.
if it is a spring, then just force the boot downwards and pull outwards and the boot will come off.
if it is a clamp, undo the clamp and pull the boot off.
look at the new boot and you will see a groove that slips onto the lip of the tub. lubricate this groove liberally with washing up fluid or similiar.
start at the top and push the groove onto the lip. work in both directions round the boot forcing the groove onto the lip until entirely in position.
if a clamp was fitted, just put the clamp in the outer groove and tighten
if it is a spring, this is more difficult and you will find an extra pair of hands helpfull. stretch the spring and push into position in the outer groove.
fit the boot to the cabinet and replace the clamp
test for leaks on rinse cycle as water level is higher. there will be some foam from the washing up fluid.
remember to make a note of which way up the door boot was fitted as there is a top and bottom
Was this helpful?
Yes
No
Popular Solutions for AEG L12700ViT Front Load
Questions and Unsolved Problems for AEG L12700ViT Front Load
Do you recommend AEG L12700ViT Front Load All-in-One Washer / Dryer?
Answer
Answer
throwing codes front load washer; maytag epic model mfw 9800 tqo what is the hc code for?
Answer
The washing machine is working fine but when you set the the dryer on it goes through the motions... (More)
Answer
when shut door to start wash, press start, a clicking noise occurs and error message comes up
Answer
Cant get machine to work, shut door and select wash program, nothing happens, all the lights come on... (More)
Answer
When I try to use the drying function I get an E320 error just bas the drying cyle begins (when the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For AEG L12700ViT Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
