Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Nothing on screen
My screen is just black and the lamp light is red and there is no error code
  • mjorlin22 Sep 05, 2008
    Im having trouble with my TV. WD-52525
  • Anonymous Sep 06, 2008
    Same problem here. New Lamp installed and lamp light on TV is on, indictating lamp is bad.
  • 4 Answers
There is a proplem in the power,open the bacage which is found behind the screen,if the thread is cutting repair it and clean you computer from dust,you will see the computer is very well.
Posted on Sep 04, 2008
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
Red light 5 blinks
your set needs attention by the authorised service - probably the Vertical scan, horizontal scan or the flyback transformer driver circuits have failed.
Jul 12, 2009 | Sony KDS-R50XBR1 50" HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Blinking red light code and screen turns goes black then turns on
5 blinks is code for lamp driver failure.Replace ballast.
Apr 26, 2009 | Televison & Video
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have SONY KDF-50E2000 about 15 months old with expired warranty. One day it just refused to turn on. I have green power light for couple seconds, after that it starts blinking red 3 times with interval....
Its definately the error for lamp cover or lamp position error either the lamp door switch is broken or the lamp contacts are not making contact
Jan 08, 2009 | Televison & Video
Standby Lamp
Count the flashes of the standby light and the gap between them as this will give you the exact error code for the fault. Then check handbook or sony forums for the solutions. Like I have said in other posts sony and 3rd party dont really go together but it does not mean that because I have had those experiences it applies to all products and components. Hope this helps.
Aug 18, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Green light blinking
It will have to be diagnosed. As the only blinking light error for that model is when the led turns from green to flashing red which indicates a lamp error. If its new I recomend returning it most retailors will freely exchange a new TV . Wish I could help more but there is no diagnostic codes for that model other than lamp error. And being that I am taking that the back light isnt working either. I would contact the retailor without delay.
Apr 11, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
