Question about HP 386209-001 Keyboard
Keyboard I am unable to type numbers on the (i called accounting keyboard) on right side of the keyboard. I have turned the "num lock button" on and do no get anything. I have resorted to using the numbers above the letters and it is a pain. Help
Click on start... and then on Run. Type access.cpl and then u will get accessibility options. Click on the Tab "Mouse". You will find a check box "Use mouse Key", uncheck it. It should work. Hope this helps you... :-)
Posted on Oct 20, 2008
Num lock not working. number keypad not working. keyboard numbers are working.
Press the num lock button - usually the top left hand button on the keyboard numbers on right hand side of keyboard.
Mar 02, 2016 | Logitech Computers & Internet
I have a Mac computer and the key board Num Lock won't turn off. I tried Fn=Shift+NumLock or Fn=NumLock but still won't unlock, Help
Hi Kip,
On the right side of the number keypad on a Mac Laptop, there is a 'Clear' button above the number 7. Press Shift + Clear to turn Num Lock on. Press that again to turn it off. If the keyboard doesn't have a number pad, press F6.
Apr 11, 2014 | IBM Thinkpad 560 Series Laptop 20h4241...
Location of the numlock key?
it is located right above the number 7 on the key pad on the right side of your keyboard
Apr 20, 2013 | Computers & Internet
Lost my e recovery management system
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Oct 15, 2012 | Acer Aspire 5920-6727 Notebook
When typing it shows numbers instead of letters, (when using the right part of my keyboard, ) Please give a solution to get rid of this problem
If this is happening only on the right side of you keyboard this usually means that the Number Lock (Num Lock) was turned on.
To turn in off simply select the "Fn + Num Lock" buttons to disable it.
Jun 14, 2011 | LG X-Note LM50 Notebook
I own an HP 510 laptop, when i type the function symbol on the right side of the keyboard is displayed for eg if I want an L 3 is typed, O is 6 etc. To eliminate this I must press the FN key to get the...
You have the Num Lock on.
To turn it off just hit the Num Lock key or press Fn and hit the Num Lock key to return the keyboard to normal.
Regards.
Jun 28, 2010 | HP 510 Notebook
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Sep 20, 2009 | Compaq Keyboard
BLINKING Num Lock, Caps Lock & Scroll Lock
Put the RAM back in or check the RAM in securely
Apr 13, 2009 | E-Machines AAFQ50400000K0 Keyboard
Acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
Dec 06, 2008 | Computers & Internet
Where is num lock button on Gateway MA7?
Fn+Scroll will toggle the Num Lock
The ison on the keyboard is a purple Lock with the number 1 inside.
Jun 07, 2008 | Gateway MX6920 Notebook
HP 386209-001 Keyboard Logo
245 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
