Question about Nikon D70 Digital Camera with 18-50mm Lens
Crash I greatly enjoyed the D70 until it suddenly stopped taking pictures. I got the dreaded ERR message. WE tried different batteries, lenses, cards, etc., but to no avail. This is a real bummer. I have used Nikons for 30 years. Currently, my F100 is also at Nikon. The back latch catches simply cracked and fell off! Plastic.A couple of years ago, the self-timer stopped working and Nikon had to replace the software circuits. (The warranty had run out.)
    Sergeant:
  • 255 Answers
The D70 has a reset button at the bottom of the camera. Firts of all, I think you have checked you have the correct lens inserted (at least D mount) and well done, checked your memory card is correctly inserted, and if you have another, change it.Checked the battery. Looked the AF modes on the body. If everything is OK, then press the reset button. If you have no answer, then take the camera to the T. Service.
Posted on Sep 19, 2005
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
My Canon 40D suddenly came down with the dreaded Error 99 for no apparent reason. I have tried all the usual, battery, memory card, lens, but no luck. Even on the bulb setting the shutter won't stay open....
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 30, 2011 | Canon EOS 40D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My fuji finpix s1 will not pull up the menu, nor can I take any pictures however the automatic focus works, the function lcd lights up but it will not work either.
rdp19 did not mention the ERR msg.
I had the same problem, however after messing with it the ERR message is up.
If RDP19 gets this, did you get it fixed.  Where and what cost?
Jan 26, 2009 | Fuji FinePix S1 Pro Digital Camera
My Canon 20D suddenly started saying "Error 99" and it won't take any pictures. What should I do?
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
  2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Aug 06, 2008 | Cameras
D70 Err message
You most likely need the shutter replaced. I see them frequently. Not something you want to try yourself, as it is an in depth repair.
May 23, 2008 | Nikon D70s Digital Camera
Nikon D70 ERR problem ,
its apparture unit has faulted. it has to be replaced
May 21, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70 Err
Sounds like the shutter is sticking. This could be due to damage or just need cleaning. This probably means that you need to get the camera professionally serviced/fixed as shutters are extremely delicate.
Nov 09, 2007 | Nikon D70s Digital Camera with 18-200mm...
Nikon D70 - err - won't take picture
Today I was taking photos and the camera quit...the top display says err. The book says release shutter, but I push the shutter and it does nothing but make a little click and the err stays. I took the lens off, and the camera does look like the shutter is open or something.
Sep 28, 2007 | Nikon D70s Digital Camera
Nikon D70 Digital Camera with 18-50mm Lens Logo
111 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
