Question about iLO LCT32HA36 Television
TV wont' turn on
I got a ilo Hdtv lct32ha36 that just died recently and won't turn on. just a red light on the front. if I unplugged it and leave it off for awhile, it will turn on again, but once it turns off, it won't turn on again and it will need to be left off for awhile again. Why is that? Someone mentioned that when it's left off, it discharge whatever. How can I fix that?
  • BettyAM Oct 04, 2008
    TV is only 18 mo. old. Won't turn on, red light is the only thing on. Tried new batteries, changing outlet. Nothing.
    Sometimes when turning off it would take a while to do so. I guess that is a sign.
  • 2,326 Answers
The failure on your LCD is due to a defective power supply. Leaky or dry capacitors is the reason for the failure. Replacing or repairing the power supply should fix your LCD.
Contact this website and ask them if they have any power supplies in stock.
Good Luck.
Posted on Sep 04, 2008
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
Power won't come on
No power signal lights appear?If no power lights try to check the fuse inside your TV.remove the back cover to see the fuse location.It is located besides the power supply.check it if busted,then replace the same value of fuse.Unplug first before removing the cover to avoid electric shock.thanks!!
Jul 07, 2011 | iLO LCT32HA36 Television
No Power
It's possible your TV when into protection mode. This happens when a part is burned out inside your TV to prevent further damage.
Try unplugging your TV for 30mins. Then see if the problem still occurs.
If the problem is still there, you may have to take it to a repair shop to diagnose the problem.
Feb 09, 2009 | iLO LCT32HA36 Television
Ilo LCT32HA36 won't show a picture but does have power
Hi, I had a computer monitor that acted similar one time and what I found were that there were some bad capacitors in the power supply board inside. They were identified by the swelled up rounded ends and the heat discoloration of them. They look like little aluminum cans with a vinyl sleeve shrunk around them with the component values written on them. A normal one is flat on the end with no signs of any leakage around them of a brownish blackish substance similar to wax or tar. They are relatively inexpensive at an electronics supply store($1-2 each) so I replaced them all. This will require some soldering and electronic repair knowledge though. The power supply could not stabilize so it just kept shutting down the picture that only displayed for a brief instant.
Good Luck!
Jan 24, 2009 | iLO LCT32HA36 Television
ILO 2600 SILO LCD COLOR TV
sounds like the power supply
Oct 12, 2008 | iLO LCT32HA36 Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Ilo lct 42ha36
HI
YOU NEED VIDEO BOARD.
GEORGE
Apr 27, 2008 | iLO LCT32HA36 Television
iLO LCT32HA36 Television Logo
143 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
