Question about Konica Minolta DiMAGE E323 Digital Camera
Is the battery charged in the condition that the batteries are in the camera connected to AC adapter?
    Master:
  • 425 Answers
No, it isn't. Please use the dedicated battery charger.
Posted on Sep 19, 2005
Camera does not respond
I see you can't even look on the screen, because you have to start the camera first, before you can switch between taking pictures and viewing. You you not even can see an error displayed on the screen.
Most obvious is the battery, or its connections. The manual says:
"The camera does not work even when batteries are installed."
Insert recharged batteries in the correct direction. "Inserting the battery and the SD/SDHC/SDXC memory card (sold separately)" (p. 13), "Charging the battery and setting up using the supplied CD" (p. 14), "Charging the battery with the supplied USB-AC adapter" (p. 17)
Battery performance may have been reduced temporarily due to low temperature. Take the batteries out of the camera, and warm them by putting them in your pocket for a while.
Then to make sure it is not the battery they advice to connect an external USB-AC adapter.:
An F-3AC USB-AC adapter (available separately) is recommended if the camera will be used for extended periods.
Note that the power cable supplied with the USB-AC adapter is for use exclusively with the USB-AC adapter. Do not use with other devices.
With the adapter, the voltage (and current it can deliver) could be enough to switch on the camera.
If it works, you should take aout the battery and check if the connection point of the battery and in the camera are clean and shiny. If not, please clean them with a dry cloth. Never use a sharp tool to clean electronic contacts. The manual says the battery will live up to 300 charge / discharge cycles. If the camera won't work with the battery and it works with the USB AC adapter, replace the battery.
Nov 16, 2013 | Olympus XZ-1 Digital Camera
Coolpix s3000 wont charge from car usb adapter?
The battery in this camera has to be removed and connect to an AC adapter to be charged.
  • Rechargeable Li-ion Battery EN-EL10
  • Charging AC Adapter EH-68P
May 15, 2012 | Nikon Coolpix S3000 Digital Camera
How do u charge the camera? What does the charger look like?
You can charge the batteries in three ways
1. Using an AC power adapter. Connect the AC power adapter to the camera trough the power adapter connector below the usb connector on the right side of the camera (looking from front). Then connect it to the AC power outlet.
2. If you have an optional HP Photosmart camera dock, plug the camera in the dock and then dock the camera. Same thing if you have a wireless dock.
While the battery is charging, the battery charging light in the camera blinks. Once the battery is fully charged, the blinking light stays solid.
It is better that you read the user manual for the camera. If you dont have one, download it free from the web: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The charging procedure is given with figures on page 6.
Jan 10, 2011 | HP Photosmart M525 Digital Camera
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
Will my ac adapter chardge my camera? I have the Olympus c-50 (zoom)
No. You do have the battery charger, right? If not, get one
FYI
When connecting the AC adapter to the camera’s DC-IN jack, be careful not to
catch the plug on the jack’s cover.
● If the battery power runs out while the camera is connected to a computer,
image data may be corrupted. It is recommended that you use the optional AC
adapter when transferring images to a computer. Do not disconnect or connect
the AC adapter while the camera is communicating with the computer. Or just make sure your battery is fully charged!
● Power is consumed continuously during the conditions described below.
This could reduce the number of pictures that can be taken.
•When the monitor is turned on.
•Repeated auto-focus by pressing the shutter button halfway.
•Repeated power zoom adjustments.
•When communicating with a computer.
● Do not remove or load the battery and/or do not disconnect or connect the
AC adapter while the camera is turned on. Doing so could damage the camera’s settings or functions.
Dec 20, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Power supply for Olympus fe-130
(In addition to the batteries provided with the camera, the following types of battery can be used. Choose the power source best suited to the situation.
AA alkaline batteries/ Oxyride batteries
The number of pictures that you can take may vary considerably depending on the
battery manufacturer and shooting conditions.
AA NiMH batteries (rechargeable batteries)
Olympus NiMH batteries are rechargeable and economical. For details, refer to the instruction manual for your charger.
(Lithium battery packs (CR-V3) and AA manganese (zinc-carbon) batteries
cannot be used.
(Power consumption by the camera varies depending on which functions are used.
(Power is consumed continuously during the conditions described below causing
batteries to become exhausted quickly.
• The zoom is used repeatedly.
• The shutter button is pressed halfway repeatedly in shooting mode, activating the auto focus.
• The monitor is left on for an extended period of time.
• The camera is connected to a computer or printer.
(The battery life varies greatly depending on the type of battery, manufacturer,
shooting conditions, etc. Because of this, there may be cases where the camera
turns itself off without displaying the battery level warning, or displays the battery
level warning sooner than usual.
The camera also has an optional accessory of an AC adapter that can be used as an alternative power source. It is model number E-7AU.
An AC adapter is useful for time-consuming tasks such as image downloads to
a computer or when running a slideshow for a long period of time.
To use the AC adapter with this camera, the optional multi-adapter (CB-MA1) is
necessary. Do not use any other AC adapter with this camera.
Note
• Do not remove or load the battery or connect or disconnect the AC adapter or
multi-adapter while the camera is on or the camera is connected to the other
equipment. Doing so could affect the camera’s internal settings or functions.
• The AC adapter can be used within the range of AC 100 V to AC 240 V (50/60
Hz). When using the shape of abroad, you may need a plug adapter to convert
the plug to match the AC wall outlet. For details, ask at your local electrical shop
or travel agent.
• Do not use travel voltage converters as they could damage the AC adapter.
Apr 16, 2009 | Olympus FE-130 Digital Camera
How do i know if my battery is being charged in my camera
The AC adapter does not affect the battery in any way. You use the AC adapter as an alternate power source to power the camera. In order to charge the battery you need to remove it from the camera and use the charger that came with the camera.
Mar 11, 2009 | Olympus FE-220 Digital Camera
Konica Minolta DiMAGE E323 Digital Camera Logo
21 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
comment
comment
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
