Question about LG Washing Machines
No rinse cycle - LG Washing Machines
  • 1,543 Answers
Check for blockage of the cold water inlet screen where the hose connects to the machine. Other possibilities include valve at other end of hose turned off, hose kinked, water valve solenoid electrically "open".
Posted on Sep 05, 2008
Machine goes into extra rinse cycle
This may seem obvious, but have you set the rinse cycle indicator switch to one or two rinse cycles? If to only one, then try move switch back and forth between one and two a couple of times to ensure that you have good contact with ONE rinse cycle.
Sep 04, 2014 | Washing Machines
Rinse cycle displays but doesnt perform the rinse cycle
If it's stuck in rinse keep adding water until the cycle is complete.
It may take a while.
This is a common complaint
Jan 23, 2013 | Gaggia Titanium Espresso Machine
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Water level on rinse is to low, on wash cycle the water level is good, I think maybe three quarts of water come in for the rinse cycle, please help. brand new admiral model # ATW4475XQ
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
Jul 24, 2011 | Admiral Washing Machines
Maytag DWU8330AAX: glasses, plates, utensils,
The rinse cycle is the same as the wash except the wash uses detergent and the rinse uses rinse aid.
The rinse cycle will dispense rinse aid if you have filled the dispenser. Check this first, that would be the most likely cause. Also in the spring as the water table table in most cities begins to rise the water quality goes down, extra calcium in the water can cause this problem.
Here is a link to help understand that. Let me know if you have questions.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 02, 2010 | Dishwashers
Extra rinse cycle
Press the button and you will get an extra rinse cycle at the end of a normal rinse cycle. A B C
May 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
49 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
