Question about Frigidaire Washing Machines
My affinity high efficiency washer will not clean clothes. I've tried everything - I think. Can you help?
    Novelist:
  • 166 Answers
Peace,
ngafm at your service!
How old is the machine and what exactly does it do?
You may want to unplug the washer for 5 minutes and try rebooting the system and then when you replug it in see if it clears the problem and starts to clean!
Let me know what happens. I'll be here all night!
Bless You
ngafm
Please give me a good rating in this site before you sign off!
Posted on Sep 05, 2008
How do I put a clean cycle on for a frigidaire affinity high efficiency top load washer?
Hello Tracy, thank you for your post!
From what you have described you need help putting your Frigidaire washer into a clean cycle. In order to further assist you I would need your model number. You can locate your serial tag (which lists your model number) on the door frame of your washer. With that information I would be happy to further assist you. -Matt
Jan 03, 2016 | Frigidaire Washing Machines
The washer is leaving residue on my brand new clothes even when i adjust the amount of soap
Hey friend, thanks for your post!
Based off the information you have provided it sounds like there could be a buildup of soap within your appliance. I would recommend performing a clean cycle on your appliance which can be done by using a hot wash cycle and a cup of bleach. I hope that helps to some degree. -Matt
Sep 10, 2014 | Frigidaire FAHE4044MW Affinity High...
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
I got a new affinity washer yesterday and when i tried to wash clothes it keeps saying pause. Then i get an error code of 41. please help model number is FAFW3801LW
this means the control board thinks the door is open check the wiring to the control board and the door switch make sure everything is connected properly
Jan 16, 2011 | Washing Machines
How do I go to clean cycle-Frigidaire affinity ATF6000fs
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Jan 21, 2010 | Frigidaire ATF6000ES Front Load Washer
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
HE Washer leaves clothes smelling bad
Peace,
ngafm at your service,
How old is the washer?
And how long has it been smelling bad?
Some front loaders over the years have had this problem and the worse used to be the Maytag Neptune!
This is what I tell my customers to do:
Friend,
ngfam1 At your service!
It is normal for some frond load washers to have a little water left in the inner tub after the wash finishes!
I do tell my customers to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make sure to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
If this will not help I would call frigidiare and tell them you must have it replaced that it is affecting your family because of the mold smell!
Believe me they will swap it out after all the money you spent on it, you deserve it! BUT REMEMBER MANY people have this problem with some front load machines!
if it's not new then perhaps the pump is faulty or the lint is clogging int he pump of the machine!
Let me know what happens!
Bless You,
please give me a rating before you sign off!
ngafm
Sep 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
