Question about Brother ULT2001
Using a Brother ULT 2003 embroidery machine. In the middle of embroidey design if I stop machine the button to restart the machine stays red and I get the msg to "attach the embroidery frame" I'm unable to start the machine back up My brother ULT 2033 won't start because it says the frame is not attached, but it is. I've tried everything. Is there a solution?
  • cherlise Nov 23, 2008
    It was fixed by an authorized dealer. The cable to the embroidery hoop sensor was severed due to the back and forth action.It was replaced.
  • 4 Answers
The solution is to take it to an authorized Brother dealer. It sounds like either something wrong with your embroidery hoop sensors, or more likely something is wrong with the brain of your sewing machine. Hopefully after all this time you've done just that. I'd hate to think of a ULT just sitting around collecting dust.
Posted on Nov 22, 2008
How do I format a floppy disk for use in a Brother ULT 2002D Embroidery Machine
Contact Brother Online Service. They can direct you best.
Nov 17, 2014 | Sewing Machines
Can the brother pacesetter ult 2002d floppy drive be replaced with usb
Julie, You should be able to have that on-board floppy drive repaired. USB is from a computer only to send a design to the machine.
Cheers,
Embroidery Services
San Diego, CA
Jul 23, 2012 | Brother Disney ULT-2002D
Restarting a design in the middle but I turned my machine of , so it lost the uploaded design is there any way to restart a design in a specific point?
Start by removing the hoop from the machine (leave the fabric in the hoop!) and turning it on so the embroidery resets. Attach the hoop again and put the foot down. Load up the design and send it to the machine. Skip blocks until you get to the block you were on when you stopped. Send this block to the machine, but do not press the green "go" button. Press the "forward" (needle down) button to advance the design until you are a few stitches BEFORE your stopping point. Now you can press the "go" button.
Dec 04, 2011 | Singer CE-200 Quantum Futura Computerized...
I have a Brother Ult 2001 and I was right in the middle of monogramming a towel using the large frame when I ran out of bobbin. I took the frame out and changed the bobbin and when I returned the frame to...
My friend just had this problem a couple weeks ago. Here's what we did. We cleaned the bobbin case with canned air lightly. We turned the machine off and disconnected the embroidery unit. Turned the machine on without the embroidery unit and ran a straight stitch. Then we turned it off, reattached the embroidery unit and touched another design of a different size. Attached the hoop without fabric just to see if it would "take it" and it did so we put the right size hoop back on and selected the design we were on originally and it worked. Some times these machines are just "touchy" and don't let you do something and after a "rest" they're ok. I hope this works for you.
Aug 24, 2010 | Brother Sewing Machines
EMBROIDERY STOPS IN MIDDLE OF DESIGN. PRESS RUN AND IT WILL RUN FOR A SECOND AND STOP AGAIN
Are you sure you are not "double-pressing" the Start/Stop button? The machine might think you have said Go and Stop straight after? Try embroiderying using the foot pedal - see if that works for you. I guess you are aware that the machine will stop for thread colour changes. Do an experiment on any old piece of fabric - load the design and press the Stop button (not the one mentioned above, but the one of the left-hand side above Fix). The light should go out. This will eliminate the colour changes - the design will sew out in one single colour only. See if it keeps running and completes the design.
I would also "park" the embroidery arm, turn off the machine, remove the arm, replace the arm, turn machine back on and try again. Sometimes it just needs to start all over to get things back on track.
Jun 14, 2010 | Husqvarna Designer I
Using a Brother ULT 2003 embroidery machine. In the middle of embroidey design if I stop machine the button to restart the machine stays red and I get the msg to "attach the embroidery frame"...
This is not normal operating behavior for a ULT, take it your a Brother authorized repair center so they can inspect the sensors and the program.
Jul 18, 2008 | Brother ULT2001
Sewing Machines Logo
355 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
