COMPUTER SPEAKERS SOMEHOW THE SOUND ON MY COMPUTER GOT DELETED, I HAVE 2 MULTI-MEDIA SPEAKER SYSTEM EP-691. POWER IS WORKING, NO SOUND. WHAT TO DO? THANKS.
  • 33 Answers
Is there a volume icon in the bottom right hand corner of the screen? If not you need to reinstall the sound card drivers. You can usually download and install these from your PC manufacturer's website (in the suppport section).
Posted on Sep 05, 2008
Have a JBL Encounter 2.1 Multi Media Speaker System need to find a power lead and speaker jack for it im resident in uk and need voltage requirements regards
you shouldnt have to worry about a speaker jack for it. it should work anywhere and a simple usa to uk power adapter will work for you it just changes the plug type and up or downs the voltage (i cant recall if uk is higher or lower then the u.s)
Mar 23, 2011 | JBL Encounter 2.1 Computer Speakers
Why is my left speaker coming out with no sound, but my right speaker (no controls on it) is working? To note, when I move the cord that plugs into the sound source, I hear crackling in the left speaker...
is the cord you move laying on a rug or carpet this will cause static
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 23, 2011 | Juster AC-691 Computer Speakers
No Sound At all from the Speakers. I have plugged and replugged in the connections. I am getting power but absolutely nothing out of the speakers. Some minor static if I wiggle the power cord,...
no sound at all it was working fine before i got additional speakers creative sarrounding withe 2 mini and 1 sub buffer how to test it its just not comming on now
Jan 03, 2011 | Bose Companion 3 Computer Speakers
Need spec and power supply for this set of speakers "Juster DC-691P"
Speakers (External, Powered), (Adapter, 9V, -Outer, +Center) Juster DC-691PASpeakers (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PA
Sep 08, 2010 | Juster AC-691 Computer Speakers
What power lead do I need for Juster 691 computer speakers
the power lead is 110/220 from outlet and the power of the speaker are 3watt 1ohm impedance o.1 distortion
What is the power adapter needed for the Pro Juster 691Pa speaker system?
Computer Speakers Juster (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PAYZNJ891701998
Aug 22, 2010 | Juster AC-691 Computer Speakers
I have no sound from my Multi-Media Alaska ms 691 speakers.
make sure that they are plugged in to the right connection in the back of the computer, this jack is usually color coded light green.
Aug 06, 2009 | Bose Companion 5 Multimedia Speaker System...
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
Can not get sound out of my speakers
Assuming that the sound is working in the computer and the SBS340 speakers are multi-media (with their own amplifier and power supply), plug the MINI stereo plug into the "green" jack (3 jacks in a row) on back of computer. Turn on the speaker switch and turn up volume about 1/3rd on the speaker. Then look for the electronic volume control (lower right corner next to the clock---will be a tiny speaker icon) , click on it and slide it up approx 1/8th to 1/4 the range. You will have to have some email or program that can supply some audio to see if it works. I have a MIDI file with gobs of numbers that I can call on.. If there is something wrong with the system, that's another story.
Dec 30, 2008 | Logitech X-240 Computer Speakers
Speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
Jun 10, 2007 | MidiLand MLi 691H Computer Speakers
126 people viewed this question
 Grubhead
Grubhead
