Question about Canon DR-9080C Path-Through Scanner
Gray the documents are coming out gray
  • 490 Answers
Check the scanner settings in Captureperfect. Try scanning in color by selecting color mode. If it works then there is no Hardware issue.
S. Mohan
Posted on Nov 08, 2008
Background on all white pages copies are gray
check printer settings or document settings back ground color settings
you can print a page color to any of the color bar settings so there is a setting that has been change to grey that is causing the problem
Dec 11, 2015 | Epson Stylus NX400 InkJet Printer
Ink cartridges just replaced and print is coming out light gray. #2 When I print e-mails or documents from e-mails--advertisements and side bars print out on my documents? Can you help me fix these...
first off the side bars printing is the direct result of the settings you are using. and must be readjusted. accordingly. The light gray print sounds like a combination of 2 separate settings, the "economode" that is set on the printer itself, and a similar setting in your print mode on the computer (never use both, only one or the other).
Mar 27, 2015 | HP Photosmart 7510 e-All-in-One -...
Gray shades Everytime I scan a white sheet of
Try adjusting the contrast and brightness settings when you scan. If the contrast is set wrong it will pick up the shade of the white paper.
Sep 30, 2013 | Canon DR-3080CII Path-Through Flatbed...
We are having HP Officejet J4580 all in one in our office. but the problem is that even if i scan a document in gray scale & PDF then also the file size come out to very Huge; Which troubles us alot...
Scanning in gray scale alone will not bring down the scannned documents size alone. In your scan settings there should be a setting whereby you lower your DPI (dots per inch) or scan resolution. The standard DPI is usually about 300. Try lowering it to about 100 and check the scanned document size again. Lower your DPI until you reach the appropriate document size for emailing etc.
Best wishes,
Jul 26, 2011 | HP OfficeJet J4580 All-In-One Laser...
Using Word 97. Applied a background (marbled gray)to a document. Saved and printed. Background is not printing, nor showing on Print Preview?
To print the background in your document, do the following:
1) Open the word document and go to File->Print.
2) When the print window comes up, click the option button at the bottom.
3) Then,tick the Background colors and images as shown in the attach picture.
4) Click OK.Then Click OK again to Print.
Feb 06, 2011 | Computers & Internet
Document copied in black & white prints
Check Printer Settings in computer for Resolution. if its print resolution is low then it will print very light gray.
Check Toner / Ink Cartridges for ink also.
To check resolution go to printer Properties by right clicking printer (from Control Panel>> Printer and Faxes) .
Mar 22, 2010 | Audio Players & Recorders
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Recent viewed documents in Word 2007 grayed out Administrator fix
this is free download
I am running MS Office 97 and was unable to reconstruct you problem
Hope this download helps
May 07, 2009 | Computers & Internet
Photoshop, separating gray shades
I'd select the different levels of gray, and cut the color out of the picture, then paste it into a new document, using the exact same document and canvas sizes each time, so that you end up with three or four new documents, each with a different level of grey. If you're familiar enough with PS, you can do so by adding four new layers, and simply copy and paste the colors to four separate layers, and just hide all layers except the one you're printing currently. PS will ignore all layers that are invisible when printing. Click the 'eye' icon on each layer so that all of them are hidden except the one you want to print.
Hope this will FixYa!!!
Jun 01, 2008 | Adobe FC Photoshop CS V8.0 for mac
Printing Blank Sheets
What document you sending? word ?
does demo and conf page come out from printer OK ?
Try installing drivers again
Sep 26, 2006 | Konica Minolta magicolor 5430 DL Laser...
Canon DR-9080C Path-Through Scanner Logo
89 people viewed this question
old marine
old marine
