Question about Maytag Neptune MAH5500B Front Load Washer
Cannot get the lid to unlock
Washing a backpack and now the cycle stalled and the lid will not unlock-help!
  • 39 Answers
Hi kirklin
if you open the detergent lid there should be a red or green cord just pull it and it should open it.
brent
Posted on Sep 16, 2008
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
Jul 10, 2017 | Whirlpool Washing Machines
Kenmore 2800*010 will not fill
It sounds like you have a bad lid switch. There is a tech sheet taped to the inside of the front of the cabinet. The part # is w10404050, made by whirlpool.
May 03, 2014 | Kenmore Washing Machines
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Washing machine will not go into the spin cycle - it stalls at the end of the wash cycle leaving the clothes soaking in a tub full of water i tried to restart at the rinse cycle and it stalls after the...
This is usually caused by a bad lid switch. Whirlpools are known for lid switch issues. If the lid switch is not telling it that the lid is closed, it will not spin. Look where the lid switch is and press on the lid directly above it -- it may start. This will prove it. You can find an exploded view (and get the part) at www.appliancepartspros.com
Feb 14, 2011 | Whirlpool Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Whirlpool Washer stalls out on rinse cycle
This is likely a lid switch problem. They tend to get weak and work sometimes and sometimes not. When it stalls like that try pushing down on lid and see if it kicks in. If so you need to replace the lid switch
May 11, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Lid switch won't unlock at end of cycle
Yes! The lid/door WILL UNLOCK after a 45 to 60 second delay, This is for YOUR SAFETY this action prevents you from opening the lid/door to a coasting washbasket. You CAN or WILL be seriously injured if you insert your hand(s) into the machine before the washbasket stops!
Mar 26, 2008 | Frigidaire FWS833A Top Load Washer
Whirlpool cabrio HE error code
The problem with this is the lid lock is broken i suggest replacement of the lid lock to solve your problem
Jan 14, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
