Question about Garden
5 hp Briggs and Stratton snow blower
No spark
  • Blaknwite Apr 21, 2009
    8 hp briggs & stratton on tiller. Installled new points/condenser and set gap @ 0.020. no spark. Was running but erattically, ie, after it warmed up, began to misfire. Noticed coil had approx. .030 gap on one side but other side was touching flywheel. Set gaps the same but still no fire.
  • 48 Answers
Easest way is to remove shutoff wire from coil and then see if you have spark - if this is a point system it prob needs points and condenser
Posted on Oct 21, 2008
Where is the spark plug 305 cc 30 inch snowblower yardork
Look for the spark plug wire which usually comes out from the recoil shoud and follow it to the spark plug
Feb 16, 2015 | Briggs & Stratton Snowblower Snow Blower...
What spark plug wrench is used to remove the spark plug on a TORO 38624w snowblower?
it is prob a 13/16 this is the most common most of the time you cannot get a wrench on a plug but a socket , if it is smaller then it is a 5/8 lefty loosie righty tighty do not over tighten the plug
Jan 20, 2014 | Toro 826OXE 2-Stage Snowblower 38624W
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
No spark and will not start
remove blower shroud off top of engine.Remove grass screen first.disconnect ignition kill wire from coils,retest for spark,if no spark check kill wire,wire that was disconnected from coils for short to ground.If wire checks ok,replace coils.Forty years in small engine repair.
Sep 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Backfires thrue carb
You may have an intake valve staying open or the spark timing may be off from a slipped flywheel and key. Can spray liguid wrench in the intake to coat valve stem . You would have to take off the flywheel hold down nut and pull starter engage ring to see if the groove in the flywheel matches the groove in the crankshaft. Ive had blowers, weed eaters, tillers and all kinds of small engines break a flywheel key for no apparent reason. Sometimes they are just a little loose and wear out or snap.
May 09, 2010 | Briggs & Stratton Intek Snow Horizontal...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Owner's manual
10-30 w, or SAE30 eg Briggs & Stratton 30.
Jan 30, 2009 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Garden Logo
488 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
