Question about Logitech Harmony 520 LCD Remote Control
Manual nice name..... where can i find a manual to down load or how do i program my remote to run my components.
  • aimpal Dec 26, 2008
    I programmed my
    TV but the cable box does not turn on at the same time as the TV, I have to use the cable company remote to turn on the cable box.
    Scholar:
  • 65 Answers
You can download the user manual of Harmony 520 on this link.
Harmony 520 User Manual
Posted on Sep 15, 2008
Step by step
What steps are you looking for? Also what is the problem? Also this may solve your issue
Copied from: voxrightnow
Programming the Remote:
Your universal remote can operate a variety of brands of components. In order for your universal remote to control your components, you need to program the remote with the codes that match the components (See Code List below). These codes enable the remote to communicate with your components. Each brand and each component has its own "language," and, by programming the correct codes into your remote, you tell the remote to "speak the same language" as your components.
There are two methods you can use to program your remote control to operate your components: Direct Code Entry and Manual Code Search and Entry. Most components can be programmed in one of these ways. Try them in the order listed.
In order to control combo TV/VCR or TV/DVD units, you must program both the TV key and the VCR•DVD key. Once programmed successfully, the TV key controls the TV functions on your unit, and the VCR•DVD key controls the VCR or DVD functions. There is a specific section in the Code List for combo units. The codes in this section should be tried first, using Direct Code Entry on the TV and VCR•DVD keys. If this is unsuccessful, follow the normal programming methods for both the TV and the VCR•DVD keys
Direct Code Entry:
To program your universal remote to control your components using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box).
2. Find the Code List below. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each brand. If your brand isn't listed, use the Manual Code Search method to program the remote control. (Refer to page 5 in the User Manual for Manual Code Search method, or scroll down in this Answer to the next section.)
3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The LED indicator light turns on and remains on. If you release the component key any time during the Direct Code Entry procedure, the LED indicator light blinks four times, and the process is exited.
4. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key. If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure
for Direct Code Entry. If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 3 and try the next code listed. The last programmed code under that component key is retained. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Manual Code Search and Entry:
If your component's brand isn't listed in the Code Lists, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Manual Code Search. This Code Search method cycles through all of the codes in the Code Lists in the event that your component's code is listed under another brand. The Manual Code Search method may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand is listed in the Code Lists, first try the Direct Code Entry method described on page 4 in the User's Manual also described above.
NOTE: To exit without saving any point in the Manual Code Search, press and release the GO BACK key.
Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained.
2. If you are programming the remote to control your TV or satellite receiver, go directly to step 3. To program the remote to control a VCR or DVD follow the preprogramming method listed below.
Preprogramming the VCR/DVD Key
The VCR•DVD key can control only one component, either your VCR or your DVD. To program your remote to control either your DVD or your VCR, you must first put the remote in the proper programming mode. Follow these directions before proceeding to step 3.
a. Press and hold the VCR•DVD key. The LED indicator light turns on.
b. While holding down the VCR•DVD key, press and release the number 2 key on the keypad to control a VCR or the number 3 key to control a DVD. The LED indicator light turns off.
c. Release the VCR•DVD key. The LED indicator light blinks four times and then turns off. Your remote is now either in VCR or DVD Programming Mode, depending on which you chose. Proceed to step 3.
4. While holding the component key down, press and hold the ON•OFF key. The LED indicator light turns off.
5. After holding down both keys for three seconds, the LED indicator light turns back on.
6. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the
7. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component
turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
8. Once you have found the correct code, you must save the new
code by pressing and releasing the STOP key. The LED indicator
light turns off. You must press the STOP key to save the code or the correct code will not be stored!
9. Once you press the STOP key, the code is stored.
Testing the Code for Maximum Functionality:
1. Once the code has been stored (see Manual Code Search and Entry Method above), use the remote to attempt to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the
code stored does not give maximum functionality, you will want to try another code.
2. In that case, repeat the Manual Code Search and Entry Method from step 1. When the component turns off for the first time, do not press the STOP key, which would store the code. Instead, with the unit now off, continue to press the ON•OFF key repeatedly until the unit turns back on. Once the unit turns back on, you have found another code that operates the component. Press the STOP key.
3. Test the functionality again by attempting to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the code stored does not give maximum functionality, you will want to try another code.
4. Repeat the Manual Code Search and Entry Method from step 1. Each time a code turns the component on or off, you have found a code that operates the remote and needs to be tested for maximum functionality. Continue through the code lists, cycling through the codes you have already tried, until you find one that offers maximum functionality.
Nov 10, 2012 | RCA RCR350 Remote Control
Tip
URC-R6 Remote Code Entry
AVEX URC R6 Universal Remote Control Entry
Follow these steps to program your URC R6 Universal Remote control:
  1. Turn on the component you want to program.
  2. On the AVEX R6, press the Component button that you want to program and the SELECT [SEL] button at the same time. Hold down both buttons for 2 seconds until the TV Component LED light turns on. This signals that you are in programming mode.
  3. Enter the three digit code for your component. If this is the correct three digit number, your device will turn off.
  4. Press the component button you just programmed (in this case TV) one more time to save the code number. The component LED light will blink three times to confirm that the code was successfully stored.
I hope that helps.
____________________________________________________________________
URC-R6 Manual Download
on Jul 14, 2010 | Universal Remote Control R6 Remote Control
Tip
I hope that helps.
on Jul 14, 2010 | Televison & Video
I have a rcr312w remote and can't program my emerson tv, can you help?
Hello
Setup codes to try with Emerson TV with RCA RCR 312W remote are:
10017, 10154, 10451, 10236, 10463,
10180, 10178, 10171, 11394, 11963
Load the remote with new batteries and proceed.
[1] Manually turn on the component you want the remote to
control
[2] Press and hold the component key (TV,
program. The illuminated ON•OFF key
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
[3] While holding down the component key, consult the
illuminated ON•OFF key turns off.
[4] After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
the illuminated ON•OFF key blinks four times when the
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
[5] To confirm that the component key is programmed with
functionality.
OK.
Sep 03, 2011 | RCA Universal Remote Control
How do I program my remote to my tv without the booklet
Hello
You can do it by code search method.
Try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
May 05, 2011 | RCA RCR311B Remote Control
Lost booklet how do =I program Panasonic TV for remote control?
It takes only a few steps to program a Jensen Universal Remote Control, but you need to know the code of the component you are programming into the remote. You can get the code from the manufacturer of the component, or you can visit RemoteCentral.com
  • 1 Manually turn on the component you want to program.
  • 2 Find the three-digit code numbers for the component brand.
  • 3 Hold the Device key down until the green indicator light comes on.
  • 4 Release the Device key. Within 30 seconds, enter in the three-digit code number. The light will flash when the right code has been entered.
  • 5 Press the Power key. If the component turns off, you have found the right code.
  • For a manual code search and entry:
    2. Press and hold the component key (TV, DVD, VCR-AUX,
    SAT-CBL)
    The illuminated on-off key turns on and stays on
    3. While holding the component key down, press and hold
    the ON-OFF key. The illuminated ON-OFF key turns off.
    4. After holding down both keys for three seconds, the
    illuminated ON-OFF key turns back on.
    5. Release both keys. The illuminated ON-OFF key remains
    on
    6. Press and release the ON-OFF key repeatedly until your
    component turns off. Wait four seconds between each keypress.
    Each time you press the ON-OFF key, the illuminated ON-OFF
    key blinks, and the next code in the list is sent. This
    process continues until all of the codes in the code lists
    have been searched. If your component turns off, you have
    illuminated ON-OFF key blinks four times and turns off,
    all codes have been search. The manual code search method
    is exited.)
    7. Once you have found the correct code, you must save
    the new code by pressing and releasing the STOP key.
    The illuminated ON-OFF key turns off. You must press
    not be saved.
    8. To confirm that the component is programmed with the
    correct code for max functionality, test the component.
    do not work try programming the remote with a different
    programming method. Be sure to retrieve the code your
    remote programmed.
    Sep 14, 2010 | Jensen 143307 Remote Control
    How to program a rca rcr451 remote
    or cable box).
    2. Locate the enclosed Code Lists.
    component’s brand. You will see a
    brand. If your brand isn’t listed,
    control. (Refer to page 6 for
    Manual Code Search method.)
    (TV, VCR, DVD, SAT·CBL) you
    your component’s brand and use the
    light turns off.
    component’s functions with the
    your component’s functions.
    DOWNLOAD the full manual with codes for free at: http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCR450C-MANUAL-OPERATING-MANUAL.html
    Aug 11, 2010 | RCA Universal Remote Control
    How to clear remote so I can program it again
    Link to the manual
    http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
    Problem: The remote is not
    performing commands properly.
    • You must put the remote in the
    correct mode by pressing the
    corresponding component key (TV,
    VCR, DVD, SAT, AUX1, AUX2) so
    the remote knows which component
    you want to operate.
    • Make sure the component is “ready”
    (e.g., DVD player has disc loaded;
    VCR has tape loaded, etc.).
    • You may have pressed an invalid
    key for the mode the remote is in
    (e.g., the RECORD key only works
    in VCR Mode).
    • If you are trying to turn on an RCA,
    GE or PROSCAN component, press
    the component key (TV, VCR, DVD,
    SAT, AUX1, AUX2) instead of the
    ON·OFF key.
    • If you’re trying to change channels,
    try pressing the OK key after
    entering the channel number as this
    is a requirement of certain models
    and brands.
    *There is a possibility that a
    programmed code may only be able
    to control some of your component
    features (e.g., only turns a
    component on and off). Follow the
    steps provided for programming the
    remote (See Programming sections
    on pages 5–7). If the component can
    be turned on and off, make sure you
    press the CH+/CH- key to see if the
    component responds. If not, try the
    next code from the list.
    Good Luck :)
    PLEASE rate my solution
    Dec 18, 2009 | RCA DIRECTV Satellite Remote Control
    I need code for rca rcr461 universal remot my tv is a ilo
    1. Manually turn on the component you want.
    2.Press and hold the TV, DVD etc the illuminated component names turns on.
    3.While holding the compnent key down simultaneously press and hold the ON.OFF key - the illuminated name turns off.
    4. After holding down both keys for 3 sec, all components name stay on.
    5.Release both keys. the component name remains lit.
    6.Press and release the PLAY key, wait for 5sec, the component will turn off. If component does not respont continue to press PLAY every 5 sec until component turns off.
    7.When the component turns off, then the correct code is blocked. Press REVERSE key wait 2 sec to see if component turns on again.
    8. Once component turns on then use STOP key - now code is stored.
    Note: use FORWARD KEY AND REVERSE KEY to go front and back on the code search.
    (sorry for the typo (if any) I dont have a scanner to scan the manual and I am typing out from the manual)
    Feb 13, 2009 | RCA RCR460 Remote Control
    Rca universal remote control
    Manual Code Search and Entry 1. Manually turn on the TV
    2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
    3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
    4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
    5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
    6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
    code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
    TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
    7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
    8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
    Jul 21, 2008 | RCA RCR311B Remote Control
    Logitech Harmony 520 LCD Remote Control Logo
    230 people viewed this question
    Top Logitech Televison & Video Experts
    Greg Ulan
    Jerry Umali
    Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
