Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Colour ink cartridge
The printer indicated that it was time to change the colour cartridge. We followed the directions for installation but the resulting pictures are lacking in defined colours. We purchased another cartridge thinking the one we had was the problem but the pictures are the same.
Help!
  • 40 Answers
The printhead needs to be replaced. Contact Kodak AiO Support so they can replace it free of charge.
Posted on Sep 05, 2008
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
Non-recognised ink cartridge
I haven't tried the Colour/B&W/Stop button combination suggested above, but on a Canon MG5250, switching off, then on, and immediately holding down the 'stop' button for 20-30 secs does seem to disable the block. After that the colour concerned has no indicator. It seems that refilled cartridges will woork for a few refills (showing low ink on the indicator) before requiring the permanent fix.
Jun 12, 2010 | Canon Pixma MP500 All-In-One InkJet...
Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Install cartridges
From the manufacturer's web-site:
http://h10032.www1.hp.com/ctg/Manual/c00186904.pdf
download the "Reference Guide", and follow the directions.
Dec 13, 2009 | HP PSC 1350 All-In-One Thermal Printer
How do i change the colour cartridge for a epson style c42+ printer - if i press the red LED button for 6 secs only the black cartridge comes into the open.! how do i get the colour cartridge into view ?
after the black cartridge moves to the ink changing position, push the 'ink' button one more time to move the carriage to the position to replace the colour cartridge. in some cases this will only work when the printer indicates that the color cartridge is empty.
Oct 12, 2009 | Epson Stylus C42+ InkJet Printer
Ink cartridge cannot be used after initialization
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
Sep 21, 2009 | HP Photosmart 3310 Printer
Canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
Sep 30, 2008 | HP PSC 1610v All-in-One Printer
Cartridge problems with the P915 Lexmark printer.
Check that the contacts are clean. Also try another catridge. Even a new on can be bad...
Geno
Mar 04, 2008 | Lexmark P915 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
35 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
