Question about Konica Minolta DiMAGE E223 Digital Camera
Frame rate of movie file
What is the frame rate of movie file?
    Master:
  • 425 Answers
The DiMAGE E223 can capture a movie at 15 frames per second. When a movie is captured while the video output is used in PAL mode, the frame rate is 12.5 fps.
Posted on Sep 19, 2005
SOURCE:
Why can't my pandigital picture frame play my movie all the way through?
Does this happen with all movies or with one particular movie?
It could be that the movie file is broken or incomplete.
You could test the file on a different computer, but bear in mind that some movie players can be more indulgent with problematic movie files than others.
Personally I have several movies that play excellent with the well-known VLC Media Player, but will consistently fail using other media player software.
I hope this helps.
May 17, 2014 | Photography
Tip
Mac Keynote Video Converter-Split and Join TM90 1080/60p AVCHD MTS to Keynote...
Convert/Join Panasonic HDC-TM90 HD Videos on Keynote for Presentation-AVCHD MTS to MOV <br />Embed/Store Converted/Joined H.264 mov Videos to Keynote '09-Mac TM90 MTS to Keynote Converter <br /><br />I had recorded some .mts videos using Panasonic HDC-TM90 as part of research. I used Keynote to make presentation. I would like to insert the <b>Panasonic TM90 <a href="http://www.aunsoft.com/final-mate-mac/">HD Videos on Keynote for Presentation</a></b>. However, the resulting HD videos are in AVCHD .mts files which could not be imported to Keynote. With the 1080/60p recording mode, the videos play great on the TM90 camcorder, however, Mac keynote is not compatible with this format, not even iMovie, Final Cut or others. <br /><br />While looking for a solution to add recorded AVCHD videos to Keynote, Aunsoft <b>Final Mate for Mac-<a href="http://www.aunsoft.com/final-mate-mac/">Best Mac MTS to Keynote Converter</a></b> is recommended as the partner to <b>Panasonic TM90 MTS for Keynote presentation</b>. It helps easily creating a vivid slideshow presentation with HD videos by converting AVCHD video to HD MOV. <br /><br />Below is the quick guide to <b>Embed Panasonic HDC-TM90 AVCHD MTS 1920*1080P videos to a presentation created with Keynote</b>. <br /><br />Step 1: <b>Import/Capture Panasonic TM90 Camcorder AVCHD files to Aunsoft Final Mate for Mac</b>. <br />Free Download Final Mate for Mac as a <b><a href="http://canon-videoconverter.com/2011/06/convertjoin-panasonic-hdc-tm90-hd-videos-on-keynote-for-presentation-avchd-mts-to-mov/">Mac Keynote Video Converter</a></b>.When Aunsoft <b>Final Mate for Mac</b> is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab. <br /><br />Step 2: Create a Movie for <b>converting TM90 1080/60p MTS files to MOV for Keynote</b>. <br />Just select one or multiple mts video files you would like to convert, cut from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. <br /><br />Step 3: <b>Splitting and Joining .mts Clips for Keynote on Timeline</b>. <br />To cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the" Delete" button next to the "Split" button to remove the unwanted .mts clips. As Final Mate for Mac is frame-accurate cutter, you can also pause the video, and click the Previous Frame or Next Frame for the exact frame you want to cut. <br /><br />To "join" another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output. <br /><br />Step 4: <b>Export H.264 MOV video file for Keynote</b>. <br />Click the Export button and choose HD MOV as output format. Follow HD Video &gt; H.264 HD Video (*.mov) to choose export format for further sharing your presentations by keynote. In this way, all video clips will be merged as one single movie for keynote. <br /><br /><b>Tips:</b> You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 30, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. <br /><br />After the conversion, I <b>store the mov video on Keynote '09</b>. Drag the <b><a href="http://panasonic-avchd-converter.com/2011/06/mac-keynote-video-converter-split-and-join-tm90-108060p-avchd-mts-to-keynote-for-presentation/">Full HD MTS videos to Keynote on Mac</a></b>,it is easy to display videos on business presentation. <br /><br /><b>Tips</b>: If you want to import and edit Panasonic HDC-TM90 MTS on iMovie and Final Cut Express, Final Cut Pro , you can choose the <b>Quicktime Movie Format &gt; Apple Intermediate Codec (AIC) (*.mov)</b> and <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> . AIC and ProrRes was advertised codecs to result in less compression and higher data rate/higher quality files for HD editing in iMovie/Final Cut Express and Final Cut Pro.
on Jun 10, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to convert Kodak video to other video formats Kodak Movie Converter is the...
How to convert Kodak video to other video formats Kodak Movie Converter is the best to use Kodak zi8, Playsport, Easyshare and Kodak Zi6 series MOV file converter that allows you to convert MOV file and convert 1080P/720P HD MOV into video format like avi wmv mpg flv 3gp mp4 and help you import/upload mov to Windows Movie Maker, Media Player, Sony Vegas, AE, etc. It works up to 500% faster than its competitors and with just a couple clicks you can convert mov and edit mov through cut, join and merge. Kodak movie converter allows you to extract stiil images, frame, audio file and select only the parts you want to convert from a large file.
Step by step guide to convert kodak video using Higosoft Kodak Movie Converter What you need?
1Download and run Kodak Movie Converter Kodak Movie Converter allows fee trial evaluation, you can convert your video file but there will be feature limitation in the output, such as watermark and timing. Purchase the full version will remove all the limitation and free online support, upgrade, even discount is available for every customer.
kodak-movie-converter.jpg 2Load Kodak videos to Higosoft Kodak Movie Converter Load the MOV movie file you wish to convert, you can load a video folder or several video files at one time, the program supports batch load and batch converting.
mov-file-converter.jpg 3Choose output video profile Kodak Movie Converter presents you a full list of output formats; you will find one that suitable for you.
In adddition, click "Setting" button, Kodak Movie Converter allows you to further customize video output, such as video encoder, bitrate, frame rate, audio encoder, sample rate, channel. Through their custom settting, you could get better visual effect. If you are not familiar with the setting, just keep the default setting.
4Basic edit the imported Kodak video before converting. Kodak Movie Converter enables you to clip videos, truncate video to several video clip of different length, crop videos, adjust video effect like saturation, brightness, contract, and flip videos.
edit-mov-file.jpg 5Click "Convert" button to start convert Kodak video When starting the process to convert Kodak video (usually .mov file) you will feel it is surprisingly fast. Converting batches of mov file is quick, easy and produces great results.
In brief, Higosoft Kodak Movie Converter is incredibly easy to use and converts MOV files fast. The quality of the converted video is always very nice with excellent quality. If you’re looking for a powerful way to convert mov file to video avi wmv mpg, windows movie maker, Sony Vegas, APP and don’t want to spend a lot of money then definitely give this a try.
on Aug 24, 2010 | Cameras
The audio and movie are not together. The audio is ahead of the movie.
your watching a divx file or h.264 video, or a torrent file, the frame rate is faster than the audio bitrate...whoever gave you that file encoded it wrong. should be mp4 video file. ">
Jan 23, 2014 | Televison & Video
How to play any other movie file in digital camera Olympus FE-370.is there any converter to change the movie file to play in my digital camera?
In general, no. Most cameras are designed not to play videos or show stills taken by other cameras or edited on a computer. This is to avoid any potential problems with resolution, frame rates, color spaces, etc.
Apr 12, 2010 | Olympus FE-370 Digital Camera
Tip
Convert Blu-ray and standard DVD to iPad, iPad Blu-ray disc/standard DVD Ripper...
Because of its 9.7-inch 1024×768 high resolution multi-touch screen, iPad is convenient and comfortable for users to read newspapers, magazines, books, view photos, experience the web, touch emails, and watch any kind of video, from HD movies and TV shows to podcasts, music videos and more. Also because there is no distracting keypad or buttons on iPad, you will totally concentrate on this big screen, and feel completely immersed in whatever you’re watching. You can imagine how wonderful it is to watch your HD Blu-ray and DVD movies on this little gadget. Are you ready to do so? If so, this article will give you a solution to the problem of how to convert Blu-ray and standard DVD movies to a compatible format with iPad. If you are looking for such a solution, just read on to get the detailed steps and the optimal playback settings for iPad.
The software you will need is Pavtube Blu-ray to iPad Ripper(for Mac: Mac Blu-ray to iPad Ripper).
Before that, go to see the iPad supported video formats as below:
H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;
MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;
Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format
Well, it is obviously that Blu-ray and DVD movies are out of the above categories, and then please follow the following guide to do format conversion before your playback.
Step 1: Add Blu-ray or DVD movies into this program
Click “DVD Rom”, “DVD Folder”, or “IFO/ISO” icon to load Blu-ray or standard DVD movies.
Step 2: Select subtitle and audio track
Click on the dropdown list of “Subtitle” and “Audio” respectively to select your needed subtitle and audio track.
Step 3: Select “iPad” as output format
Click the pull down menu at the end of “Format” to select an output format for iPad. Here I choose “iPad Video MPEG-4 (*.mp4)” for instance.
Step 4: Click “Settings” button to adjust audio and video parameters
You are allowed to adjust codec, aspect ratio, bit rate, frame rate, sample rate and audio channel in the popup window to optimize the output file quality. Following are the recommended settings to get best playback quality.
Video:
Codec: h264
Bitrate: 2500kbps
Frame rate: 30fps
Audio:
Codec: aac
Sample rate: 48khz
Bitrate: 160kbps
Channels: Stereo
Step 5: Click “Convert” button to start conversion.
Once finished, you can get the output files for your iPad via clicking on “Open” button effortlessly. Afterwards, connect your iPad to your PC, and then sync the videos to iPad via iTunes.
Learn more: Convert/rip DVD and HD Video to your iPod,iPad,iPhone
Portable Media Device
on Apr 29, 2010 | Computers & Internet
I just bought a Z1285. I put SD memory cards with pics and videos made with my Z730 in it and i can view pics ok but when i try to view videos screen reads"unrecognized file format" Whats up with this
Hi this is a simple one!
The Kodak Z730 records movies at the following resolution and frame rates 640 x 480, 12 fps, 320 x 240, 20 fps while the Z1285 records movies at the following resolution and frame rates 1280 x 720, 640 x 480, 320 x 240, 30 fps therefore you cannot view the Z730 movies on the Z1285 and vice versa.
Jul 10, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Apr 02, 2009 | Kodak EasyShare SV811 (8858946) Digital...
What format does a .mov need to be converted to to play on a DF?
You can try these these file formats and compression rates:
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} File Format: MOV
File Format: AVI
You will have to look for a free video editing software and use it to be able to follow the above formats.
Mar 29, 2009 | Kodak 8" LCD Digital Photo Frame
I'm having trouble getting .avi files to play on my TD350a.
Using the converter "AVS Video Converter 6", converts virtually video format to any other format, I have, thru tial and error converted full length movies 3+GB .mpg to ~650MB .avi. It works great!
I use the settings:
Video:
Size: 320 x 240 pixels
Bit Rate: 1200kbps
Frame Rate: 25 frames/second
Aspect: Microsoft MPEG-4
Audio:
Bit Rate: 192 kbps
Channels: 2
Sample Rate: 44100 Hz
Audio Format: MP3
The program costs $59.00, but the free download is full (but with a logo - center screen). Test it out. If it's worth it to you, buy it.
Ken
Jan 07, 2009 | Cameras
Konica Minolta DiMAGE E223 Digital Camera Logo
73 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
