Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv not working
I have a dmtect tv just stopped working the light is on but nothing
    Scholar:
  • 98 Answers
Remove all the external connections connected to the tv.then un plug the tv wire from the power outlet.then after some time just plug only the tv wire back in the power outlet.do not connect the other devices and check if the tv is working as normal or not.if it does not works then
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board.
also check for any loose soldering joints on the power supply board.
calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
thanks.
Posted on Oct 13, 2008
On my dish remote for tv 2 sat button stopped working and wont light up. all other buttons work. i have changed batteries but nothing changed. How do i fix this because i dont wan to waste money on an
Kevin rico,
I can definitely check this out with you. Does the SAT button light up when you press any buttons at all? If you press SAT, can you operate the receiver?
If neither of those work then the remote most likely needs to be replaced. If you would like to try that option, just send me an email at thomas.faust@dish.com and i'll assist you further!
Tommy Faust
DISH Social Media Representative
Jul 05, 2012 | DISH Network 142923 Remote Control
I am tying to retune my 19inch lcd dmtect but my remote wont go up and down if i try put 0 it gives me the number 6 how can i retune without remote or could u help me fix it?
sounds like something may have been spilled into your remote, take it apart and clean both the rubber with the contact (the side that faces the pc board) and the "contact" side of the pc board with rubbing alcohol
Jan 15, 2011 | Televison & Video
Remote Stopped Working
It is possible the IR sensor is bad. Most of the time if it is a remote issue, the light on the remote will not light up. Does the remote that came with tv still control any functions? I would try the remote that came with the tv, and then go from there, but it sounds like your IR sensor has gone out on you.
Mar 31, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv just stopped working, as if no electricity is getting to tv. but green light is on, at the box between wall and connecting port of tv. nothing is on the tv screen, no static, nothing.
YOU HAVE A POWER SHUT DOWN THER IS A TIMER ON YOUR TELEVISION THAT AFTER 30 MINUITES OR AN HOUR OR ETC. IT IS PROGRAMMED TO TURN OFF AUTOMATIC. GO INTO THE MENU AND SET IT TO 0 OR OFF
Mar 06, 2010 | Televison & Video
Front panel lights appear then nothing and tv does not turn on
How many times do the lights blink? This is a diagnostic code
May 25, 2009 | Sony Televison & Video
Remote Control wont Work
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
Jan 25, 2008 | Televison & Video
Quasar VV-1302 13in TV/VCR unit. Remote stopped working
Test your remote by placing it in front of a video camera or web cam if you have one.. Press the buttons and watch the cam to see if you see the light coming from the remote.. The camera lens merely slows the light to a visable spectrum.. If no light your remote is not working... If light replace the sensor in the TV..
Bill
Jan 14, 2008 | Quasar VV-1302 13 in. TV/VCR Combo
Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Oct 22, 2007 | RCA RCR412C Remote Control
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
