A friend has an air cconditioner system that keeps freezing up on the inside,i checked the levels and the unit calls for 350 on the low 300 on the high however he has 350 on the low,50 on the high,what do you think,air movement problem or possibly a restricted line?
  • 706 Answers
Sounds like the hiside and low side difference is too great.. Spec cited is 350 Low and 300hi with a delta of 50 versus what you are seeing of 350 Low versus 50 High ..delta of 300.. Could be contamination or a leak..
Posted on Sep 05, 2008
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
Why is the outdoor unit freezing up all the time when the outside air temp is 12 degC ?
Most likely low on refrigerant. Call a local tech to find the leak and refill to correct level.
Jul 06, 2014 | Fujitsu Heating & Cooling
My goodman unit is freezing up. It is frozen from the line running out of my house than if u look down into unit, the freeze continues inside
Hello, the suction line will freeze either due to low airflow such as dirty air filter, blower wheel, evaporator coil or a weak blower motor. Also, a low refrigerant charge can cause the suction line to freeze up.
Jul 16, 2012 | Goodman Heating & Cooling
My ac keeps freezing up
You need to have the unit serviced . The freeze-up can be caused by blower failure while system is running or not coming on at the call for cool. Goodman has a thermal relay that bring the fan on after a short delay. Your evaporator coil may need to cleaned. You can have a low refrigerant charge. A lot of companies offer a low cost service check. We come out and do a thorough check of your system and can identify the source of your issues and sometimes freeze-ups can be caused by something as simple as a dirty air filter. I would start there first.
Jul 06, 2012 | Goodman Heating & Cooling
Why does the low pressure hose on outside a/c unit freeze up? It has ice and the a/c does not cool inside the home
Either the ac compressor is weak,or the freon level is too low,There would be need of ac gauges connected to the system to find out the actual cause.
Apr 16, 2012 | Honeywell Heating & Cooling
My A/C evaporator is freezing up, and wont cool the house below 85 degree
Check your filter and make sure you have one in place and it is clean. This is either a low inside airflow problem or system is low on freon. If you have strong air flow from vents and filter is been kept clean then low freon is most likely. Run system in on position with cooling off to make sure ice is melted. When water stops draining. then restart system . If it starts frosting up at outside unit shortly after start up it most likely is air flow. If you don't have at least 15 degree drop from registers in a few minutes and indoor humidity is not too high inside and airflow decreases and air gets colder just before it freezes up then it is low freon.
Jun 29, 2009 | Heating & Cooling
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Jun 19, 2009 | Whirlwind FH-778 Air Conditioner
The copper line going from my outside unit up to the inside unit keeps freezing up. This on the outside of the house.
This sounds like you are low of refrigerant. Or you evaporator needs cleaning. Have it check out to see if you have a leak in the system
Jun 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Air conditioner freezing
Check your filter in the furnace, Then check the coil to make sure it is clean. If neither of these two solutions fix your problem you may be low on refrigerant.
Jul 22, 2008 | Samsung AS18A6RB Air Conditioner
Rudd model ubhk-24jinfg
Check your filters inside the furnace, replace if needed. Then check to ensure that the fan is running inside the furnace. If these two things dont fix the problems, I would imagine you have low refrigerant issues. In that case you should call a service company.
Hope this helps ya please rate me.
Jun 20, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
