Konica Minolta DiMAGE E223 Digital Camera Logo
A
Anonymous Posted on Sep 19, 2005
Movie clips
Does the camera record movie clips?
Anonymous
Level 3:
Master:
  • Master 425 Answers
  • Posted on Sep 19, 2005
Anonymous
Master
Level 3:
Master:
Answers
425
Questions
Helped
65885
Points
1267
Yes, it does. The camera can record a movie clip up to 60 sec. It has an audio function when recording movie clips.
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
1helpful
2answers
Camera shows hd movie recording disableD
HD movie recording disabled: SOLVED for 2 HDRSR5's (work and home): After copying all movies to computer, "DELETE ALL" from HD view. Evidentally if you have been deleting movies using computer, the still images used for 'scene selections' remain and fill its capacity. You must be in HD view when choosing Delete All (that is, rather than just deleting all Standard movie clips)
How to play back movie clips
i having a problem with D: 5f08 5e02
I have a sony dsc-s500 digital camera I can't figure out how to play back video's. Does it actually have the feature to record?
DSC-S500 can record short movie clip with sound and you can playback it on camera and can transfer that movie clip to PC
Check below jog-dial mark to set camera to record movie clip.
To playback, set camera to Playback.
Need further info, let me know.
Thanks.
Jan 28, 2009 • Cameras
HOW TO USE THE CAMERA
Hi Sonali,
To record movie clips first of all press the menu button, this will refelect the shooting menu of your camera, select the first option of shooting modes by the navigating keys circling the menu/ok button. Then press the right arrow on the navigating keys, this will open the modes of shooting. Generaly while first use always AUTO is selected, you may scroll up to select the movie mode and then press ok button. Now you are ready to record clips. Click on the shutter button (picture button on the top of the camera) to start recording clips and when you are done re-click to stop recording.
I hope this will help ;-)>
Regards
Premanshu.
Ticking sound on movie recording
I have the same problem. On one movie I made it doenst and on the other it does. The orinals are fine.
No sound on movie playback
This camera does record sounds. But, it doesnt look like it has a speaker in it to play them. So, yes unfortunately you wont be able to hear what you record unless you are using something else to playback what you have recorded.
Good Luck.
Sanyo digital camera model- vpc5500
Playing Back Movie Clips
You can play back the recorded movie clips on the LCD monitor screen. However, the
sound recorded with movie clips can only be played back on a computer.
1. Press the button.
2. Use the four-way controller (����) to go
through the images until the movie clip you
want to play back is displayed.
�� To view the previous image, press the
four-way controller (��).
�� To view the next image, press the
3. Press the button to start playing back
the movie clips.
�� To pause or resume movie playback, press the button again.
Dec 25, 2007 • Cameras
No audio when recording movie clips on HP735 digital camera
go to video settings and switch on the audio option for video
Movie mode function
The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode.
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
