Question about SanDisk Sansa e260 MP3 Player
Sansa e260 It wont hold my songs. When i transfer the songs the green bar goes up and it says its all transferred. BUT. When i turn my sansa on it says refreshing database but there are no songs on it afterwards.....Please help
    Problem Solver:
  • 6 Answers
Apparently there is a known problem with older firmware with some MP3 files having info in the ID part of the file that makes the player go crazy. So update your firmware or listen to different music :-)
"Bugs Fixed: Stability· Hanging at Refresh Database with certain ID3 tag genres."
This info from page below. Also shows you how to update to latest firmware which may fix your problem
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Posted on Sep 06, 2008
How do you reformat the sansa E260?
There are several possibilities.
1) The songs that you loaded may not be compatible with the player - iTunes files, for instance.
2) The songs that you downloaded may not have transfer rights - i.e.: they will play fine on a computer, but they will not play on an mp3 player.
The solution to the above two possibilities would be to download songs that are in mp3 format only. They do not have strings, stipulations, headaches, etc. attached to them.
Possibility #3 is that your mp3 player is in the wrong USB Mode. Songs that show up in MSC mode do not show up in MTP mode, and vice versa. To change this, go into your Sansa player's settings menu and change the USB Mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260
You need to synch them to Rhapsody or whatever music service you pulled the songs from. also, make sure your music service subscription supports transfer to portable devices instead of simple transfer to a computer.
Jan 15, 2009 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip (can you use iTune Cards)
You will need to buy the music from Itunes..once you buy them you will have to transfer them to your sansa using your windows media player...Itunes wont allow you to transfer to your sansa using their applications...Just make sure your device is on MTP mode and go to your windows media player to transfer the songs..
I hope that helps
Thank you
Computerrep
Dec 18, 2008 | SanDisk Sansa e260 MP3 Player
Sansa 4Gb Wont let me add or delete songs anymore!
If the PC does not recognize the player, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 Car Connection Problem
Since I haven't heard back, I am going to clear this from my queue
May 16, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
yes, set up ur configuration setting... uncheck the option "sync automatically" so that it will not transfer songs to ur sansa automatically....
Feb 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e60
Try using WMP or explorer to transfer songs
Jan 05, 2008 | SanDisk Sansa e260 MP3 Player
Problem with transfering photos and videos to my Sandisk Sansa e26 and uploading music...HELP!
Everyone - install quicktime to get the right codecs to fix the video conversion issue
everyone else:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Sep 20, 2007 | SanDisk Sansa e260 MP3 Player
Please help me!!! im desperate!!! sandisk sansa e260
if your sanas e260 does'n syncronize with your computer or say data base..., take the battery out and conect it with out the battery.
May 08, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
94 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
