Toshiba Cinema Series - Power button flashes red won't go on
    Genius:
  • 2,920 Answers
Power supply is out
Posted on Sep 04, 2008
I have a 55 in Toshiba Cinema Series HD the colors are out of alignment so I have three pictures stacked behind each other. Is there an adjustment or repiar
I have a Cinama Series HD Toshiba and it has a Problem with the picture theres red letters behind the white , it like the colors are stretched, theres red eye above the real eyes and same with the teeth area, what could be the problem?
Nov 09, 2010 | Toshiba TN61X81 61" Rear Projection...
I HAVE 2000 TOSHIBA 50" CINEMA SERIES MODEL 61HX70. WHEN I TRY TO TURN IT ON, IT DOESN'T WORK, BUT THE RED LIGHT FLASHES CONTINUOUSLY. WHAT CAN I DO?
U have tools lilke a soldering iron,solder,desoldering pump or soldering wick?U know how to do basic soldering?Try website like Tvrepairworld.com to buy a capacitors kit,to fix the DM power supply board,will fix this problems.
Sep 09, 2010 | Toshiba 50HX81 50" Rear Projection...
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Toshiba 61' cinema series rear projector
check for loose connections and or bad convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
good luck
please mark the post with a fixya!
Feb 07, 2008 | Toshiba 61H71 61" Rear Projection...
possible regulator ic. in the power supply.
Nov 20, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
Electro Med Services...
