Question about Nikon Coolpix 4500 Digital Camera
Zoom toggle switch problem
The zoom toggle switch on my Coolpix 4500 suddenly stopped working. Does anyone have any suggestions for reliable and reasonable repair work of this nature?
  • yipg Nov 23, 2008
    The zoom button (specifically the "T" one) stopped working all of a sudden a few weeks ago. It feels like the mechanism underneath is malfunctioning, as if the button is already pushed down. The zoom-in function itself is actually fine, because I can go to the "close-up" mode and the lens will zoom in automatically. I just can't use the toggle button to zoom in manually. Hope this makes sense...
    I wonder if there's an easy fix to this problem. Any idea/suggestions would be much appreciated!
  • Anonymous Apr 10, 2009
    Thanks to aboniks for solution #1. I've got my camera apart and have been looking at the rocker switch. There seems to be a nub on both sides of the switch, but one might be a little worn. (I assume you mean the small bumps on the back of the switch and not the vertical posts that are closer to the ends of the switch). Here's my question. Were you able to remove the switch to do the glueing {if so how?)? I've got fat fingers and it seems impossible to glue the bump with the switch in place.
  • 4 Answers
You need:
1: a small and strong phillips screwdriver.
2. a small piece of medium strength plastic.
(I used a wall anchor like you would use for drywall)
3. superglue
4: about 15 minutes
5. some gumption
6. a bit of sandpaper, in case you screw up step 4.
step 0: You are about to void any warranty. Accept this, and move on. Take out the battery and the memory card.
step 1: remove case of camera. be careful not to strip or loose your your screws.
step 2: gently give the thing a shake. likely a tiny piece of black plastic will fall out. this is the piece that originally attached to the back of the zoom rocker button. if it doesn't come out, don't worry.
step 3: take a look at the back side of the still functioning side of the rocker button. you will see a tiny nub on the back. this nub compresses the pressure switch that is built into the circuit card of the camera, activating the zoom.
step 4: cut a piece of plastic that is about the right thickness to replace the missing nub on the non-functioning side of the button. you will be better off cutting it a bit too thick than too thin.
step 5a: VERY carefully superglue the bit of plastic to the back of the button. you don't need that much glue.
Setp 5b: let me repeat, YOU DON"T NEED THAT MUCH GLUE!
Step 6: Let the glue dry. completely. I mean it.
step 7: replace the case, and about half the screws. put the battery and card back in.
step 8. power on, and test the zoom. It should work now. if it feels like the button is too loose, or still isn't making contact, you cut the plastic too small; Sand or snip it off and start again.
Step 9. If it feels like the button is too hard to push, the plastic bit is too large. You can cut it down a bit, sand it, or just put the rest of the screws in and be thankfull that you repaired your camera for about 2 cents worth of material, and 15 minutes of work.
Step 10: make sure you don't have any extra parts. make sure you didn't screw up another button while you were mucking about.
I've done this. It works. Repaired mine about 9 months ago, and no issues since...well, I put the button in upside down, but it works exactly the same, so that doesn't count as an issue.
If FUBAR your camera, I'm not responsible.
Long live Nikon,
-aboniks
Posted on Dec 10, 2008
    Genius:
  • 2,985 Answers
Contact the Nikon Technical support for a repair opinion Then look up your local Internet for a repair firm Bear in mind the likely cost will be heavy. It may be a case of you paying a lot of money for shipping/insurance/Inspection/only to find it cannot be repaired because of lack of parts.
Posted on Jun 12, 2007
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
ZOOM BUTTON STICKING..how do i fix this?
It is possibly an issue with the zoom motor, not the switch itself
Aug 21, 2017 | Agfa Cameras
Zoom lever stopped working on Panasonic lumix DMC-FZ8
Does it say anything about the lever under zoom levers in your owner's manual?
Nov 07, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
My Zoom button on Nikon coolpix4500 isn't working can it be repaired?
yes it can be repaired, just take it to a service center to get it repaired
Apr 20, 2010 | Nikon Coolpix 4500 Digital Camera
Nikon 4500 Coolpix
If u tried to hold up a 1000 lb weight what do u think would happen???
Well putting 12V into a 4V spicket will do the same thing.
Nov 09, 2008 | Nikon Coolpix 4500 Digital Camera
Nikon coolpix 4500 uv lens
I bought a 4 lens kit - I think from Amazon. It was a long time ago.
The size is 28mm.
yes, here it is
http://www.amazon.com/Nikon-28mm-Filter-Set-Coolpix/dp/B0000521B9
Oct 14, 2008 | Nikon Coolpix 4500 Digital Camera
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
305 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
