Question about Dishwashers
Dishwasher not working
I have a Kenmore dishwasher , Model # 363.14375790, Serial #FT331026R. When I turn it to "Start" it does start, but no water goes into the tub. I haven't had to use it for a while. I read the owners manual for :"Dishwasher will not fill with water"& the Water inlet valve is not clogged , I'm not turning the dial too far. Could you tell me what to do. This happened once before & the repair man took off the bottom panel & turned something. Help Me!!!
  • 706 Answers
Difficult to say for certain exactly what will fix your problem but it is not out of the realm of possibility that the inlet valve is sticking closed.. The repairman may have given it a tap to free it up so that when it was energized.. it opened and let water in for the wash cycle..Just because that valve wasn't clogged doesn't mean it wouldn't stick.. If you can access it .. try giving it a light tap on the housing when the DW is cycling.. Hope that gets you going..
Posted on Sep 05, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
My Kenmore dishwasher Model @ 587-1511590 goes on but no water is comming out ?
Do you hear a 'click' when it is supposed to start filling the machine--if not, then the water inlet solenoid has likely failed. Make sure the water is turned on under the sink and there are no kinks in the supply hose. Hope this helps!
Sep 22, 2010 | Kenmore 15529 Built-in Dishwasher
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Won't stop cleaning to go to dry
I have not worked with this Kenmore model, but:
It would be good to check the heating element to make sure it has not failed. Some dishwashers will wait forever for the water to come up to temp before it goes to the next cycle.
If the heating element checks out:
-IF it has a knob/dial that you turn to start the dishwasher on any cycle, that timer/controller has most likely failed.
-If your dishwasher does NOT have a dial as described above, then the main controller card (PCB) has most likely failed.
May 05, 2009 | Kenmore 16072 - Multiple Color Built-in...
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Hot water for dishwasher
Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
Oct 06, 2008 | Dishwashers
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Kenmore 665.16705891 dishwasher
First make sure it will run by hitting "cancel' or turning the timer to drain cycle.What is the Model& Serial number???I'll be happy to get this solved for you. :)
May 17, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwashers Logo
149 people viewed this question
Top Dishwashers Experts
